Step 2Rev 1.1 - Materials
And the answer is that it's a work in progress.
The biggest problem was that I used a hand drill because I did not have drill press. All of the holes were crooked and none of the axes aligned. So would this work if you had a drill press? Maybe, but I think you would still need to come up with an ingenious to increase the performance of the sliding axes. This may be achieved by adding ball bearings or using UHMDPE plastic.
At any rate I am going to include the printouts and construction documents in case you want build/modify this design. If you build one or have any suggestions please email me and/or attach a picture.
You can fast-forward to Rev 1.2 to see a working prototype if you like.
Rev. 1.1
Materials:
+ (1) Dremel
+ (1) Phillips screw driver to be used as a Stylus
+ 20ft of 1x2 hemlock (mdf or plywood may be better because it will be less affected my expansion and contraction of natural wood)
+ 5' 11 3/8 of .5 Stainless steel pipe (electrical conduit would be fine)
+ (1) 3/4" or smaller pipe clamp ($0.79Hardware Sales)
+ (1) 1.25" pipe clamp ($1.29 Hardware Sales)
+ (1) 2.5-3" pipe clamp ($1.29Hardware Sales)
+ (16) 2.5" wood screws
+ (34) 1.5" wood screws
+ (7) .5" wood screws
+ (6) 8-32 x 1" screws (this is to lock the Dremel and stylus in place.)
Useful Tools:
+Safety glasses and ear plugs: Safetly First, attempt project at your own risk! I will not be held liable for any injury, medical expense or death as a result of think about, building or using the project once completed.''
+ Hand drill
+ Miter Saw (hand saw could also be used)
+ Drill press
+ Pipe cutter
+ Various drill bits including 1/8, 1/4, .5 or slightly larger
+ Tape measure
+ Ruler
+ Router bits for a Dremel
Add Comment
