Dremel Cork Sanding Bands/drums
5,742
150
9
Posted in WorkshopTools
Introduction: Dremel Cork Sanding Bands/drums
--Watch the video above for all the steps / Veja o video acima para todos os passos--
How to do easy and any size Cork Dremel sanding bands / drum sander, wood glue and plastic tube (diy homemade rotary tool)
Como fazer "discos /bandas" caseiros para multi tool feitos com rolha de cortiça, lixa, tubo plástico e cola para madeira
Step 1:
Cut the sanding paper in 2 cms strips
Cortar a lixa em tiras de 2 cms
Step 2:
Wrap the adesive papper tape around the plastic tube
Enrolar a fita de pintor á volta do tubo de plastico
Step 3:
Put the wood glue on the strips and wrapped around the plastic tube, use some paper tape to fixed in place whiule it dry.
Meter a cola para madeira nas tiras de lixa e enrolar á volta do tubo, usar um pouco de fita para a lixa ficar no lugar enquanto seca
Step 4:
After a few hours the glue its dry and you can cut it in smaller pieces
Depois de a cola secar pode cortar em peças mais pequenas
Step 5:
Cut a wine cork, put it in the dremel and grind the excess until it was the same diameter of the plastic tube.
Corte uma rolha e usando o dremel vá lixando ate ter o mesmo diametro do tubo.
Step 6:
And its done !! you can use diferent diameters and different grids
E pronto !! pode usar diferentes diametros e diferentes graos de lixa.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    9 Comments
    I would have never thought anything like it
    Very brilliant idea!
    This should be listed with the Build A Tool contest. Definitely a worthy entry.
    Tanks, i´m going to try :)
    Smart! Have to try this.
    This is the best Instructable ever on making sanding sleeves, one even gets to drink some wine so as to have a cork for the project too! ☺
    Tanks, i did it 1 year ago ;)
