3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dremel Micro Mini Disc Sander
video Dremel Micro Mini Disc Sander
In this video I convert a bit on my Dremel into a mini 1.25 flat sanding disc for finishing my jewelry pieces.  By mounting the rotary tool in a Dremel workstation, I am able to make it function almost as a little bench sander/ polisher.  I can easily switch to a finer sandpaper grit without even removing the disc from the Dremel.
The video is a little long.  I suppose because I spend time explaining what I'm trying to accomplish  My favorite workspace is inside the house, and I can't exactly have big noisy power tools blasting away! Here is one of my many modifications to make something I couldn't find.
20 comments
Mar 15, 2012. 4:05 PMwandrist says:
You can buy the disc arbor at Foredom electric.
https://02d2854.netsolstores.com/rubbersandingdrum.aspx
Bottom of page.
A-M338 Mandrel, Disc, 2" Dia., 1/8" Shank
Price: $8.40
Disc mandrel with 1/8" shank for mounting 2" PSA Sanding Discs in flex shaft handpieces and BL Lathe.
Dec 10, 2011. 10:28 AMRay from RI says:
Excellent tutorial...!
You might want to mount a plexiglass barrier between you and the tool in case one of your objects your sanding get knocked out of your hand and into your face.
Ooooor just wear a protective face shield which I guess would be safer.
Keep up the good work!!!
Oct 16, 2010. 11:45 PMoakironworker says:
Great build I have to do this. I love when something cool can be made out of simple and cheap stuff like this.
I don't know if you are, its kind of hard to tell in the video but avoid being in the plane of the disc. I had a larger disc explode and the hospital called the cops because they were convinced it was a bullet wound. That side of my leg is still numb 30 years later. Yours is smaller but spinning much faster.
Greg
Dec 26, 2010. 8:59 PMtechnosasquatch says:
Isn't that why dremel says not to apply pressure to the face of the disc tools
May 21, 2011. 1:39 PMmdog93 says:
If it was me, I would make a wooden disc, router/ drill half a recess for the screw then mount that onto the mandrel. To make it more convenient i would use that self- adhesive Velcro (hook and loop) sheet you can buy and stick one side to the wood and stick other part to different grade sanding papers. That would make it easier to change. Another thing is if you keep the piece you're sanding in the lower quarter of the disc, it won't try to grab it outta your hand as much, and if it does- the piece will hit the table or go down, not up in the air or towards your face.
Just my thoughts :) Good idea though, i don't know why you don't jut get a better disc to mount sandpapers on as standard with tools like this.
Nov 4, 2010. 4:42 PMtwighahn says:
enter the dremel contest
Jan 28, 2011. 1:06 PMtwighahn says:
we have to be its rules lol
Nov 3, 2010. 9:25 AMripit says:
i remember about 25 years ago dremel did have something like this. i wonder why they don't have it anymore?and from what i see in the vid yours works much better than thiers did!
Jan 9, 2011. 1:21 PMgroovy says:
nice ible
Oct 17, 2010. 1:52 PMdaniboi1977 says:
This is an awesome idea! I've been struggling with the same problem with my jewelry...I hate sanding for hours, but that little screw always scratches things up. Having a very limited income, I've forced my Dremel to do just about anything you could do in a full jewelry studio. Except for act as a rolling mill...if you can figure out how to do that, you'd be my hero forever! lol. Thank you for sharing this!
Dec 9, 2010. 12:52 PMmarcgoovaerts says:
Well, looks very good. Only hope I'lll find such 'Sticky Dots' over here in Europe.
But I've never seen the black tool you use for cutting sandpaper discs either. Could you give me the name and make of those things ?
Dec 30, 2010. 11:23 AMNekayah says:
This looks great, and I want to make some. Unfortunately, I am deaf, and although I could get a pretty good idea of what materials you were using (I'm very familiar with Dremel accessories), I couldn't hear their names. And where do you get the sticky dots? Fabric stores? Craft stores? You had a really good shot of that product, but can't remember seeing that particular item. I don't know how many times I've cursed that central screw: many thanks for figuring out a way to overcome it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:riseabove
