Introduction: Dremel Saw Table
How to Make a Dremel Saw Table.
Step 1: Materials
- dremel
- 2•2 sheet of plywood
- T square
- hinge
- latch
Step 2:
Cut out wood to the following measurments (all in inches)
All half inch plywood
2-6&1/2
6&1/2-8&3/4
Four 4&3/4-1&1/4
6&1/2-11
All quarter inch thick
2&1/2-11 with a 1&1/2 by 2 rectangle taken out of one corner.
1&1/4-9
11-1&1/4 with a 1/2-2 rectangle taken out of one of the corners.
Step 3:
Cut a groove for the hinge 3 inches away from the end of the (1&1/4-11) you cut. Then screw the hinge in the groove, then screw the (1&1/4-9) on top of that.
Step 4:
Cut notches in two of the ( ) to hold the back end of the dremel, and the other two for the front end of the dremel.
Step 5: Assembly
Assemble the pieces together to form the holder.
Step 6: Table
Get the only piece left, that is your saw table. I
Step 7: Your Done
And you are done.
Woodworking Contest
Portable Workstations Contest
