This instructable will guide you through the steps to make the dress up organizer shown here.  If your kids like to play dress up, but you don't like to have the clothes and all of the accessories scattered around the house then you will want keep reading.
TOOLS:
Drill and Drill Bits
Wood Saw (Miter or Manual)
Jig Saw
Hammer (Brad nail gun will save some time)
Clamps
Framing square
Tape Measure
Sand paper
MATERIAL:
(3) 1/4" x  2' x 4' Sheets of Plywood - Or enough to make all of the pieces.  These worked good for me because I don't have a truck to haul full sheets of plywood.
(2) 1" x 2" x 6' Pine boards
(1) 7/8" x 4' Wooden Dowel - Mine was poplar wood
1-1/2" wood screws
3/4" x 18 gauge brad nails - Or similar finishing nails if you don't have a nail gun
Step 1: Cut the Panels
SETUP A CUTTING GUIDE
If you are using a jig saw like me you can setup a guide, using one of the 1" x 2" x 6' boards, to help you make a straight cut.  First, measure from the edge of the saw base that will be against the guide to the blade (see Picture 2).  Let's say this dimension is 1-1/2".  Then, clamp your guide board to the plywood and add or subtract the 1-1/2" dimension depending on what side of the guide you are cutting.
MAKING THE CUTS
You will need to cut the following size panels from the 1/4" plywood:
- (3) 1' x 3' Panels
- (2) 1' x 4' Panels
If you are using the same size materials from the material list 1/4" x 2' x 4' panels you can make the following cuts:
-- Cut 1' off of the 4' length on two of the 2' x 4' panels. This will leave you with two 2' x 3' panels.  Then cut each of the two panels in half so that you have four 1' x 3' panels, one of which will be extra.
-- Cut the third 2' x 4' panel in half to get the two 1' x 4' vertical panels.
Remember the old saying -- "Measure twice, cut once"
Penolopy Bulnick says: Jan 17, 2013. 1:31 PM
Oh my! I wish I had had this (and all those awesome dresses!!!) when I was little :D You should enter this into the Holiday Gifts Contest!
Jessie Marie says: Jan 3, 2013. 1:01 PM
Cute! What an awesome idea!
magifarm says: Dec 30, 2012. 4:05 PM
What a great idea! It could easily be decorated to suit any style, and has lots of other possibilities. It would be very useful as a winter outerwear organizer for young kids. You could put a boot tray and plastic bin in the bottom for boots and hats/gloves/scarves, and then little ones could quickly find their own stuff for those busy mornings getting ready for school!
melvinkat (author) in reply to magifarmDec 30, 2012. 6:29 PM
I like that idea. We have winter gear all over the place right now!
laxap says: Dec 30, 2012. 10:06 AM
Very nicely designed and finished!
sniffydogs says: Dec 30, 2012. 6:19 AM
BRILLIANT!!!!!!!!
What a great idea!
manderson27 says: Dec 28, 2012. 2:23 PM
wonderful! Can't wait to make this with a small tweek, going to use a pre-existing boy box base
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
