Drill Battery Rebuild - NiCd to Lithium
5,670
81
9
Posted
Introduction: Drill Battery Rebuild - NiCd to Lithium
Drill/ screwdriver battery rebuild to Lithium using battery holder for 18650 cells (so no spot welding needed) and BMS. After rebuild original charger can be used for charge.
Part list:
  • Battery holder for 18650 size batteries
  • 3x Sony VTC4 18650 2100mAh 30A batteries
  • BMS to control charge/ discharge
Step 1: Soldering
At first I soldered wires to battery holder, after that soldered BMS board and battery pack plug
BMS was glued to battery holder using double sided tape
Step 2: Fitting
Little bit of cutting and now batteries fit battery pack case
Then secured using electrical tape
Check fit, done
Step 3: Charging
As BMS was used, original charger can be used for charging
Step 4: Finished
It was quick and simple battery pack rebuild
Screwdriver works as expected
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
7 Comments
That link on another instructable is actually how I got here. Great collection! Thanks.
Thanks for noticing and thanking.
Question: Say I did this on a Craftsman 19.2 Drill battery, would a Craftsman Multi-Chemistry charger (for Lithium Ion and NiCd batteries) work for the modified battery (to revive a few "dead" ones I have but also to move to lithium). I was considering getting a kit that comes with 2 "real" lithium batteries and a multi-chemistry charger.. and "upgrading" several "dead" batteries I have but I also have 1 or 2 NiCd batteries that still work. Thanks
Congratulations for this awesome instructable. The only snag is that this only works when the drill charger is not intelligent ...
Never mind, just found it on the photo. thanks for this instructable btw!:)
Do you have a link or a part number of the BMS that you used?
