Introduction: Drill Chuck Key Holder
Picture of Drill Chuck Key Holder
There are excellent other instructables here for this solution. However, I made this one and thought should share it.
What you need:
Strip of silicone rubber
Pizza cutter
Shrink tubes of small and large sizes
Step 1: Split the Strip Down the Middle
Picture of Split the Strip Down the Middle
I used a pizza cutter for better control but any art knife or box cutter would work as well.
Split it down part way only. Leaving long enough split ends that can be bent over the chuck key grip bar.
Step 2:
Picture of
Slip over a large size shrink tube over the cut to act as a tear arrestor.
Slip over the smaller size shrink tubes over the split end.
Bend the split ends over the chuck grips and grip it in the shrink tube
Heat the shrink tubes and you have your key end done
Step 3: Fasten to Drill Cord
Picture of Fasten to Drill Cord
At the other end, slip the large size shrink tube over the end, roll the end over the drill cord and heat the shrink tube to fix it.
Although, I have shown the key holder fastened to the drill end, a better idea is to fasten it at the plug end so you are forced to unplug every time you use the key.
Step 4: Final Assembly
Picture of Final Assembly
This is how it looks all done.
I used the silicon strip off a take up wheel from a broken printer.
You could also mould a strip from Sugru. I tried the Sugru but I think the strip I made was too thick as the split ends broke while bending them over the chuck handle and over the cord. But will try again once I have some more Sugru in hand.
segetem (author)2017-10-02
Thank you Swansong.
Swansong (author)2017-09-29
That's a great simple solution :)
About This Instructable
640views
12favorites
License:
More by segetem:Drill Chuck Key Holder
Add instructable to:
