This is a very simple trick to have less cleaning up to do after drilling house (internal) walls..
You might need to drill your wall for any reason, my reason is because houses in this part of the world are generally mason-walled, and drilling-anchor-screw is usually the neatest way. Although most of the time it's rather over-kill (just for hanging picture or painting frames etc), Concrete nails are ugly and usually leaves a bad crack or even chips the plaster (they use very rigid plaster around here).
It keeps my wife, mother, mother-in-law, all happy with the results and how clean i work... :)
p.s. the pictures in this 'ible is kinda overkill, much like the drill-anchor-screw on walls for hanging light stuff..
maybe it's me.. maybe it's just a phase..
Remove these ads by
Signing UpStep 1: Tools and Materials
- A piece of paper, A4 or standard magazine size is good.. I always use pages from old magazine or brochures (like in the picture).
- sticky tape. it's better to use masking tape to be sure there'll be no glue residue left on the wall.
Visit Our Store »
Go Pro Today »
Sooo simple i never thought of it...
Thanks!
Cheers..
nice to hear it works for other people as well.. :)
This is a nice trick. I normally use a vacuum and hold the hose with one hand while drilling with the other but it can be kind of a pain.
I used to do that as well but found this alternative..
masking tape: Totally with you!
I would normally use masking tape that i always have around, somehow that day there were none to be found.. so i tried this cheap cardbox tape, tried a small piece and it worked fine..
Maybe because it was very cheap, not too sticky, wouldn't hold a cardbox properly..
Actually, this reminds me about another trick i've learned to make tapes less sticky and less paint-removing, to be used as temporary marking or masking, in case you're stuck (no pun intended) with the very stick ones or even duct tape - or duck tape if you prefer:
Stick it to the ground or exterior wall to get some dust on the glue, or to your palm (oils and dust on your palms will do, but dont get it on other hairy parts of your body!!). It'll stick less and can be used as "emergency masking tape"..
= hey.. there's another idea for my next 'ible... :p [man! now i'm sure that i'm addicted!!!] =
yeah, i hate cleaning up drill dust/sand from tiled floor, can't imagine if i have to clean up from carpets! :)
