3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drill Powered Yarn Winder
I wanted to submit my own version of the drill powered yarn winder. It is basically a large bobbin winder.
You will need:
two plastic lids
a straw
duct tape
drill
Step 1Assembly
Assembly
Drill a hole in the center of each lid.
Put the straw onto your drill bit and cut to the length you want it. The only reason I covered it with duct tape was because the bit ripped a hole in it while I was sliding it on. I am using a 5/16 bit, and a McDonalds drink straw. Alternatively you can put a knitting needle in the chuck, or a dowel instead of using a drill bit, but if you skip the straw to cover the bit  you will have a hard time getting the yarn off the bit.
Slide one lid to the base of the bit, then pull a little yarn through the other lid and put it near the top.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:moxiepurple
