Drill Powered Yarn Winder by moxiepurple
I wanted to submit my own version of the drill powered yarn winder. It is basically a large bobbin winder.
You will need:
two plastic lids
a straw
duct tape
drill
Step 1: Assembly
Drill a hole in the center of each lid.
Put the straw onto your drill bit and cut to the length you want it. The only reason I covered it with duct tape was because the bit ripped a hole in it while I was sliding it on. I am using a 5/16 bit, and a McDonalds drink straw. Alternatively you can put a knitting needle in the chuck, or a dowel instead of using a drill bit, but if you skip the straw to cover the bit  you will have a hard time getting the yarn off the bit.
Slide one lid to the base of the bit, then pull a little yarn through the other lid and put it near the top.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
