3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drill Small, Precise Holes.
Step 2The Jig
The Jig
You can skip this step if you already have a right angle jig. If not, read on...
We need something to hold our drilling target and our spacers securely in two directions. It's not hard to build with some scrap wood and a couple of bolts. You could even use an old picture frame.
To build a quick and dirty jig:
Supplies:
  • Scrap wood
  • Wood glue
  • 2 carriage bolts, washers and wing nuts. Get the appropriate size to fit though the holes of your drill press base. In my case 3/8" by 2" long.
Tools:
  • Saw
  • Miter box, or protractor or some other way of determining 45o.
  • Drill.
  • Clamps.
First give the scrap wood a light sanding if there are any uneven sports. Then mark an angle at 45 degrees across the face of your scrap wood and cut the wood in two along the mark. A miter box or miter saw can help you cut it accurately.
Second flip one of the pieces over and put them together. This should make a 90o angle. If it does, glue and clamp them securely. If not, try again.
Finally after the glue is dry, drill appropriately sized holes through the jig so the bolts will be able to fasten it securely to the drill press table. (3/8" holes in my case.)
Got all that? Good, lets go!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
186
Author:Grathio(Grathio Labs)
Creative swashbuckler. Writer for MAKE Magazine, presenter of inventions on TV, radio, magazines and newspapers. Professional problem solver. Annoyingly curious. Hacker of all things from computers ...
more »
