Remove these ads by
Signing UpStep 1Locate the area of the tile to be drilled with the diamond holesaw
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Can you imagine the effect of a diamond drill slipping on a very expensive marble tile?
1) You have to remove and replace the tile. Perhaps smashing it off the wall with a hammer and chisel. Regrouting and refinishing.
2) The cost of the tiles to replace and the cost of labour.
It is possible to drill a tile freehand and at an angle with practice.
With the anti-slip guide plate there is no chance of the drill slipping and you will have a 100% accuracy when drilling a hole into a very hard tile.
So the question then becomes: Why risk it?
The thing with the larger holesaws for items like service pipes, radiator pipes, hot and cold feeds to sinks is that the hole is much bigger.
If you try to drill on duct tape alone the core will not bite into the tile.
On bigger core drills you need some mechanism to hold it securely in place and thats the reason for the application of the yellow anti-slip guide plate.
Once stated the hole actually self guides so the plate is no longer required after about 10 seconds of drilling.
About the cooling of the diamonds - yes it is important to eliminate heat from the crown (or rather the bond that holds the diamond to the metal part of the crown). So I am pleased you noted that we covered that part (Whew...) Agree - Yes a wet sponge simply held underneath is THE quickest way to cool them. And of course it collects the dust! Sometimes the simple ideas huh..... And perhaps thats half the point of sharing stuff on instructables.
YES YES YES we are looking for someone in Australia to help us get this product to the retail market. I will contact and send you details Lftndbot but if anyone out there reading this post knows of any retailers (plumbers outlets, tile shops, builders merchants either large or small) then please call me direct on
0044 1992 410636 or email me anytime at richard@365drills.com
http://www.instructables.com/files/deriv/F7F/JIES/GHI9CUX6/F7FJIESGHI9CUX6.TINY.jpg
Its a hot tap. A cold tap. And a spout. To fill a bath.
Thank you, that's my curiosity satisfied (after >20 months)
L
