After dreaming about making one for a long time, I finally went ahead and did it. It was a lot of fun to make, and it worked pretty much as advertised. The biggest problem I encountered is that I was over driving the fan motor and I probably could have chosen a more powerful one that could have handled more tubing (more weight). I will solve this problem for revision two.
Anyhow, without further ado, here is how to make your own.
Remove these ads by
Signing UpStep 1Go get stuff
A box fan
An umbrella
Ribbed tubing
A 1' foot metal tube with a diameter slightly bigger than your motor shaft
A rod clamp slightly bigger than your metal tube
Zip ties
Assorted tools
i think the length off the tube makes the pith higher/lower, longer tube=lower pitch
(The comment above is NOT a criticism - you should see what I've got planned ;¬)
