3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drought Tolerant Front Yard - Converting Lawn to Soil
This is a process for converting your front yard to good soil with no grass, without ripping up every blade of grass or taking the top layer off your soil. It actually builds up the soil while killing the grass. It is also extremely inexpensive (water and fuel for hauling compost).
I did this because California is facing an impending drought, this may not change in the next few years, and frankly I'm tired of watering my front yard. I want only drought-tolerant plants in my front yard, and fruiting trees and bushes on a drip system.
Also, I happen to live in a city with clay soil, and this will improve it tremendously.
Step 1Step1: Before
Step1: Before
Right side of front yard. I had allowed the grass to grow long. I was planning to overhaul it. Your picture, of course, may look very different on Step1.
The heir apparent helped me. He's a good waterer.
20 comments
Feb 26, 2010. 6:32 AMmegmaine says:
Thank You!
I will try this to smother out the grass this Spring, just as it is coming up, in preparation for a Chamomile lawn! I have a tiny lawn so I can start enough Roman Chamomile from seed, to do the trick thriftily.
By the way, if it survives in your area, Roman Chamomile smells nice, is drought tolerant, tolerates light foot traffic, confuses some vegetable pests, attracts beneficials, and never needs mowing if you don't mind an ankle-deep lawn. If you grow Roman from seed, you will get flowers you can harvest for tea.
I will take photos of my project and see if I can make an Instructable on the whole thing! Thanks again, I will do the cardboard method, starting now as it is pouring rain daily.
Aug 7, 2009. 12:58 PMkokopelli_fella says:
My brother has a house in phoenix, with a huge back yard. The problem is he hates to mow, so he's just let it all dry up until so he's at the point where his front and back yard are both wastelands of dirt. Any suggestions for plants for that area to be used for this 'ible? I doubt he'd do it, but it's worth a try.
Aug 7, 2009. 3:44 AMwelshwaters says:
What a great idea, we live in Wales and even though we have got enough water here, we will follow your instructions so next year we can plant a wildlife garden in the front of our house. Thank you for the step by step instructions.
Jun 22, 2009. 6:16 AMtreesneedtobehugged says:
To help your plants in your new lawn grow you can use a week manure tea.
Jun 18, 2009. 12:04 PMsir_h_c says:
I've tried this same method a couple of times to start new garden plots. Once it worked great; Put it down in the summer and planted the following spring. The second time was in Oklahoma where lawns are largely made up of Bermuda grass. It just crept up right through the layers! Know what you're up against, I guess.
Jun 20, 2009. 2:08 AMdchall8 says:
Bermuda won't necessarily come back. I smothered about 200 square feet of it a couple years ago with 2 inches of sand and 2 inches of mulch on top of that. Anyone thinking of doing this needs to check local prices. In my neighborhood compost delivered costs about $70 per cubic yard and it takes 4 cubic yards per 1,000 square feet to pile it an inch deep. You should be able to get truckloads of chipped trees from a tree trimmer for free, though. Many municipalities give away a coarse compost if you are a resident and you load it and haul it away. I could be wrong but I think you will regret having smothered your lawn before the end of the year. In my experience picking weeds out of bare soil has always been more trouble than weekly watering and mowing a dense stand of tall (3-4 inches) grass.
Jun 19, 2009. 6:47 PMCapnChkn says:
All you all is so sweet! It depends on the amount of moisture your soil gets in one season. If you lay the compost on top of the corrugated paper, it gets enough moisture, and the temperature is right, it will lay the weeds in the dirt, Lay the cardboard overlap about 6 inches (15cm). In the heat, the pile will heat up, it needs time to cure. This is the right time to try this technique, but don't expect fast results. The pile needs to cool and so on... I'm just growing Capsicum in the hot pile, I didn't get the technique until spring of this year. I don't know why I didn't think of it before. Cap'n!
Jun 19, 2009. 7:43 AMericCycles says:
I believe this is called "Sheet Mulching". When I did it, I made the mistake of only using a single layer of cardboard (I should have used two or three). I put down clover seed on top, since its nitrogen fixing. A friend did his entire backyard that way, resulting in no weeds, great soil, but an incredible slug problem. Apparently all that decomposing vegetation material is just a smorgasborg for slugs.
Jun 18, 2009. 4:44 PMstrmrnnr says:
Here is something for you to check out. This guy states, "There is enough aerobic bacteria and fungi in a good 5 gallon batch of aerated tea, that is the equivalent of about 10 tons or 40 cubic yards of regular compost!"
He tells how to make it here:
http://faq.gardenweb.com/faq/lists/organic/2002082739009975.html
Your yard should be about ready for a good dose of it by now. It will speed thing along.
Jun 18, 2009. 5:03 PMstrmrnnr says:
Also if you happen to till this lawn up in the Fall or add additional layers to your treatment this Summer I would suggest adding a lots of char in one of the bottom layers. It will help to hold the nutrients while still breaking up the solidness of the clay soil. It is funny how it works - it helps drainage but also helps to hold water. Carbon is a good thing.
Jun 19, 2009. 2:42 AMstrmrnnr says:
Here is a little chart that may help some. They say the ideal ratio for good 'good' bacterias growth in the soil is 30:1 - carbon-nitrogen.
Jun 18, 2009. 9:27 PMCalorie says:
Beware the picture new features, such as add images via drop and drag. It just erased a detailed message of wild flowers sown by seed and how they might be an excellent option.
I know it is a Beta feature, but it shouldn't eat my messages.
Anyways, try Americanmeadows.com
They sell seed in bulk, either single spieces or mixed varieties for all sorts of areas and climates. I've used them and found their mixes to be excellent. Be sure to check their members meadows to see what others have done. They've used their seeds to eliminate mowing in large meadows, encourage wildlife (butterflies, etc), mitigate sewage impact and just look plain cool.
I've spread plains coreopsis over an empty field and it is really coming into its own this year.
Check out this photo of what it can look like. The photo is from the Ritz, and I think it says a lot that they used the idea as well.
Jun 18, 2009. 11:42 PMCalorie says:
That's unfortunate. I live in an unincorporated part of Florida. We are basically part of Tampa, and live in close proximity to the city. However, there were never any suburb rules established on my street, nor does the city bother us (no jurisdiction.) The budget has been dramatically slashed by a very poorly conceived and misleading constitutional amendment that did little to cut actual property taxes (which were already among the lowest in the nation.) The average Floridian homeowner saved about $240, or to make it relative...the cost of a Big Mac Value Meal, regular size...not value size. Code enforcement really doesn't exist unless your neighbor really gets worked up. And you would have to be building a nuclear reactor to get the code enforcement guys out. American Meadows guarantees their mixes against weeds. But if it becomes a concern, try square some sort of square foot gardening. Someone on 'ble has done this with success. Good Luck in California. It's going to get bumpy.
Jun 18, 2009. 9:53 PMA good name says:
Lawns should be quite drought resistant if the soil is good.
Jun 18, 2009. 9:28 AMdmcunningham says:
This has been a great method for treating areas that you would like to grow something, and don't want to mess with removing the grass. Thank you for sharing your method of this technique.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:lisascout
