Step 3Prepare the garbage can
Then drill lots of holes all over the garbage can to provide aeration to the bacteria that will be composting your waste.
Finally, and this is the slightly tricky part, you'll need to cut a 'door' into the body of the garbage can into which you'll place waste and out of which you'll hopefully extract usable compost. If you're using a jigsaw, I suggest setting the bevel to 45 degrees so that the blade is tilted towards the center of the door. This will help to form a tight seal and not let compost spill out when you're spinning it around later. After you've made the cut, attach hinges to one side and some mechanism for keeping it closed on the other. I also attached some little metal plates on the top and bottom sides of the door just to keep it nice and secure.
comments
Add Comment
Add Comment
