3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drum Making: Spraying A Sunburst Finish
An easy drum building method is to achieve a sunburst finish with aerosol cans for a simple DIY Drum Making project.
Step 1Prepping The Shell
Prepping The Shell
Sand the drum shell with 320 grit paper, and then wipe it to remove the dust. Wiping the drum with a shop towel, and then a Tak cloth is the preferred way to properly remove all the dust.
4 comments
Aug 4, 2009. 5:15 PMChicken2209 says:
too much black, needs to be more even too
Feb 24, 2011. 6:42 PMPryo Chain says:
...that's not the point.
Aug 14, 2009. 11:16 PMDoxxRoxx says:
Something else that makes this job easier is to place the shell on a 'Lazy Susan' (rotating table). Now you can turn the shell without having to move your body around it. If you can motorize the rotating table, so much the better. Variable speed, even better! Also, I would go with a paint sprayer. Much more control over the paint flow. Even an airless would suffice.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:DrumMaking(Guerrilla Drum Making DVD)
