3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Drunken drawing robot !
Inspired by the pocket drunken robot, I wanted to give the robot a job to do. I decided to let the drunken robot make some drawings. To make your own you'll need the following:
materials:
3 felt-tipped markers
a button cell battery
some adhesive copper foil
a vibrating motor from a cellphone or pager
a laser cutter ( run to your local fablab, or order from ponoko! )
some plexiglass or wood for laser cutting (light wood seems to work best)
Here's some in action:
Step 1Materials and mesurements
Once you have your materials ready you'll need to make a couple quick measurements. We're going to be making a special plate to hold everything, so you'll need to find out the diameter of your pens and your vibrating motor. We'll use these measurements to cut out holes in the plate to hold the pens and the motor.
25 comments
May 26, 2012. 5:54 AMrabidiga says:
My Cubscout pack did a similar project for a district show 15 years ago. They used 3 markers glued to large "big gulp" plastic cups. We mounted small motors with an offset propeller sticking out of a clear plastic dome. Everyone made theirs unique with paint and extra hardware glued on. It looked like an invasion from outer space drawing artistic masterpieces on large sheets of paper. What fun it was. Kids and parents both had a blast.
Thanks for your post. You brought back a terrific memory.
Aug 5, 2011. 2:05 AMIITO says:
i think this will be.....
cool!!!
Oct 22, 2010. 9:59 PMbryandhispup says:
I dont have nor have access to a lazer cutter, is there a good way, or you can suggest an alternative?
Jul 29, 2011. 9:28 AMhfreeborn says:
a jigsaw maybe?
Nov 21, 2010. 4:18 AMBRUL says:
i'd say use scissors? :P
Jun 19, 2011. 4:21 PMfdomínguez1 says:
how did you put the motor so it turns the platform and not the motor itself?
Sep 19, 2010. 11:31 AMsashadistan says:
With a couple of adjustments this would make a great introduction to electronics project for my KS3 year seven group. Thanks very much.
May 26, 2010. 11:47 AMsci5 says:
This is a great project! Getting them to turn on and off was kind of a problem, so we took two of them and used computer wires and connected them to a 9V battery and an on/off switch off to the side. Though the switch worked great the robots did sometimes get wrapped up in the wires. We also used two different size vibrating pieces of a Play Station 2 controller instead of one from a cellphone so that the two together would make different size circles.
Dec 8, 2009. 3:19 PMilldoyourdrugs says:
What kind of alcohol did the robot drink?
Dec 29, 2009. 9:13 PMEvilthingamabober says:
 WAY too much ink. It keeps throwing it up all over the paper.
Dec 9, 2009. 5:14 AMbowmaster says:
Cool. Make a thousand.
Dec 21, 2009. 9:32 AMZaphod Beeblebrox says:
and unleash your army of a thousand of them in a paper factory!!
Dec 21, 2009. 9:46 PMbowmaster says:
Viva la revelution!!!!!
Dec 11, 2009. 1:28 PMthepelton says:
I may just make this.  I have an Epilog laser, and I found that I can get real good results from eighth inch birch plywood available from Woodcraft.com, and I can find vibrating motors at sciplus.com.
Dec 7, 2009. 5:25 PMZaphod Beeblebrox says:
genius!!!!!
Dec 8, 2009. 5:20 PMMehehehful says:
Agreed. =S
Dec 8, 2009. 9:58 AMboxen says:
NERDS (just kidding)
Dec 8, 2009. 9:57 AMboxen says:
Im not a physco nerd but it still pretty cool
Dec 7, 2009. 11:30 PMGrathio says:
Fantastic!  Glad to see someone has found a good job for those lushes!
Dec 7, 2009. 10:51 AMJayefuu says:
I wonder if altering the angle of one of the pens would shift the balance and make it do shapes other than circles.....
Dec 7, 2009. 11:59 AMlemonie says:
It's naturally inclined to do circles, adding another motor running at a different speed (or not) would be nice to try.
L
Dec 7, 2009. 2:13 PMlemonie says:
Oh yes, are you thinking of doing it? Another idea would be to add something (on springs) to relieve a bit of the weight from the pen-tips.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:skullbee(Pelletron)
