3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dtv Antennas I have tried or will try.
  • Screenshot-Screenshot-YouTube - Homemade HD Antenna 1.0 - Mozilla Firefox.png.png
  • Screenshot-Screenshot-YouTube - Homemade HD Antenna 2.0 - Mozilla Firefox.png.png
  • Screenshot-Screenshot-YouTube - DIY TV antenna by PAK - Mozilla Firefox-1.png.png
  • Screenshot-Screenshot-FoldedDipoleFullFrontal.jpg (JPEG Image, 370x600 pixels) - Mozilla Firefox.png.png
  • last photo ←
Some of the home made OTA DTV (over the air digital television) antennas I have tried (or going to try). I will add additional pictures as I test them.. Since your mileage may very I will not rate them. One was even just a telephone wire cable (not pictured yet). If you have any suggestions for antennas, please let me know.
More: http://www.instructables.com/id/Dtv-Antennas-I-have-tried-or-will-try-part-II/
There are lots of things to test. Vertical or horizontal position, whether they were meant to be uni-directional or omnidirectional, how populated are the stations are in your area, whether the stations are all in on major direction or spread out in a circle from you, and lastly what kind of signal booster are you using or not using.
Interesting link:
http://bfn.org/~bn589/antenna.html
Latest Tv antenna: http://www.instructables.com/id/Foil-based-fractal-antenna/,
http://www.instructables.com/id/Yagi-foil-HDTV-antenna/
12 comments
Dec 29, 2011. 8:09 AMShartmaster says:
66tbird FYI- HOAs are no longer allowed to ban outdoor TV antennas, no matter how big or really freakin ugly
Mar 4, 2011. 8:08 AM66tbird says:
At the start of this DTV thing I must of built a dozen of these types of antennas in all flavors. I'm an extra class ham so its second nature. Had ok results from most. On a whim I tried my very old regular TV antenna. wow, went from 17 channels to 38. I had been noticing lots of old antennas being toss out and waiting for large item garbage pickup. In a few days I had plenty of raw material to build from and a few really high-end virtually new units. After some more study on the actual freq used in dtv I realized the elements over 20'' or so were not necessary,(for my area). I trimmed back those to make another array equal to the smaller elements. Stuck it on a pole, pointed it at a city 150 miles away and bingo. I get all their stuff and my local channel plus some on the backside. 55 channels total at times, 44 normally and only 23 in my language which only 18 I watch. Boy, what a hobby.
Anyways, Computohought, your little number is a great example of a good antenna. With a little math you can taper and space to fine tune the elements to catch the 450-650 Mhz using some harmonics really well, A quality amp well help if the signal is steady but low. If it's a drifting thing I've not had much luck on the amp side using an indoor antenna.
Mar 4, 2011. 3:59 PM66tbird says:
Good, 'leave it alone' was what I finally had to do after working for that last few channels that I ended up now using or were dups.
One more I've setup on a home where outdoor setups were permitted, (HOA thing). We turned the small element array on its side. Mounted two more identical ones also vertically but at different angles to point a different mountains or cities. With an amp he does really well pushing the signals from four major cities to four tv's. Over 70 channels with dups but different times.
After it was all done I told him about Hulu,, haha
Feb 11, 2011. 4:18 PMRedneckEngineer says:
I have built and are currently useing the first one. I would be really interested in your results on the others in comparison. The phone line one sounds interesting as I have thought along those lines but I never took it to anything more than idle thoughts. I'll be waiting to see what you got in the works. =)
Feb 12, 2011. 12:07 PMRedneckEngineer says:
Hhmm...not what I was thinking at all but I can see how to maybe use that with my idea. I was thinking of useing the already installed land line as the antenna and hooking that to the coax. Since I no longer have phone service (use cellphones only now) I could create the antenna and wire it to enter the house on the unused line, then splice it to coax at the back of the TV. I might have to work this up when I get time. Feel free to try it out if you want and let me know how it works if you do.
Feb 11, 2011. 11:53 AMdosadi says:
The cantenna in the center photo is for WiFi, not HDTV. I don't know about the other two, but most cantennas are for WiFi, which runs at a much higher frequency.
Feb 11, 2011. 9:45 AMw2sqr says:
Yes, our mileage might vary but it would be very useful to know how they worked for you. The actual performance for us might vary but the skew between them should probably remain the same for everyone.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:Computothought(Computothought)
Educator, technician, unchef, and chief bottle washer. Be sure to see http://www.instructables.com/community/Computhoughts/ for updates and status on projects.
