Warning: it is possible that you might make a bad connection, and short out your computer's power supply. I recommend that you test this with a separate 12 volt power supply multiple times as you proceed, to make sure it is working at every step.
Remove these ads by
Signing UpStep 1Material
2 identical or very similar 80 mm fans
3 computer expansion slot covers
lots of electrical tape
2 machine screws and their corresponding nuts
old cd drive
5000 ohm rheostat (variable resistor)
on/off switch
insulated electrical wire
Tools:
drill
1/8 inch bit
3/8 inch bit
soldering iron
solder
12 volt power supply (for testing)
alligator jumpers (for testing)
hot glue gun
wire strippers
pliers
I already had all these parts, so this cost me a big old zero dollars, but if you had to buy everything except a cd drive, this would probably cost you 20 bucks or so.
i have filled all my pci slots (two taken up because drivers wouldn't install lol)
I have wires running all around my case, yet yours is so perfect!
great 'ible, 5*s
