Remove these ads by
Signing UpStep 1Getting Your Materials
You can get most if not all of what you need at Radioshack or comparable electronics stores.
You will need:
(1x) Medium sized project box (Catalog #:270-1806)
(2x) Battery Packs(without on/off switch) (Catalog #: 270-391)
(2x) DPDT mini-switch (Catalog #: 275-626) Make sure this is an ON-Off-ON
(1x) Solar Cell(6v 50 mAH)(Catalog #: 277-1205) This part is more expensive, if you have smaller ones, put them together to get about the same, the higher the amps the faster the batteries will charge but do not go too high obviously.
(1x) LED. This part you can get by itself, in a multi-pack, or with a built in resistor. I used one with a built in resistor to simplify the wiring. If you do, do not put the resistor showed in the diagram into the wiring) (Catalog #: 276-270)
(1x) 150 Ohm Resistor. You ONLY NEED THIS if you do not get an LED with a built in resistor.
(1x) Rectifying Diode(the smallest they have will do fine)
(1x) PSP Charger. If you have an extra use it, if not you can pick one up pretty cheap.
(8x) Rechargable AA batteries.
You will also need the following tools:
Wire... A few feet will be fine, this is just to make your connections with the existing wires.
Solder
Soldering Iron
HeatShrink(not needed but I used for good measure)
Hot Glue Gun w/ Hot glue.
Drill with bits(1/4 inch bit)
Im planning on attaching 4 or more panels on to a backpack and having this case on the inside with different attachments for psp, and usb. also i was planning on having 4 sets of 4 rechargeable battery's, ( 2 for usb, and 2 for psp) so just like here one set could charge while im using the other set.
so what do you guys think?
