3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dual Swiveling Pole Mounted Garden Hose Reels
So you want two hose reels? You don't want to drill holes into your house? You also want maximum flexibility to pull your hoses out (and reel them back) from any direction? You sure are a demanding person.
You should not deny yourself these pleasures. If you have some handyperson skills then you too can achieve the zanadu of hose reel setups that I have in my backyard.  Long before Instructables I had this dream too. I bought two of the best plastic hose reels I could find and modified them to do everything above and they worked fine for about 10 or so years until the plastic does what all plastic does when exposed to the sun...It degraded and failed. I need to buy some new hose reels. After some searching I bought two of the Ames True Temper 2391200A Decorative Bronze Wall Mount Hose Reels off of Amazon for $90.44 each delivered free. I wanted the Liberty 200' Stainless Garden Hose Reel Hanger 703-S2 I saw on Ebay for $229 shipped free but I could not swallow the price. The Liberty would have been a lot easier to mount than the Ames due to the fact it had a mounting plate on the back. It would have looked cool too.  But I digress.
You may not have all the tools I had to put this together but you can improvise and do things different to get there. Don't be afraid.
After the first time you grab the hose and head out in any direction you want to walk in your yard and the hose reel easily swivels to follow you letting the hose pay out like kite string you will then know why you passed this way. To reel the hose back in with the same swiveling capability will launch you into total hosial zen indeed.
Step 1Materials You Will Need
MATERIALS
1) 2 Wall Mount Hose Reels (you could mount 1, 2, 3 or even 4 Hose Reels on 1 pole if you want)
2) 1 Metal pole ( I used an old galvanized chain link fence pipe 1 3/8" OD)
3) 1 Top pole swivel bushing mount + 2 lag screws. This bushing mount is a short piece of steel pipe with a flat piece of steel welded to one end of it and 2 holes drilled into the flat ends to screw it to the underside of the house eve (wood). The bushing (pipe) OD should easily fit (but not too loose) inside the ID of the Metal pole.
4) 1 Bottom pole swivel bushing mount + 2 cement bolts. This part is exactly the same as the Top pole swivel busing.
5) 4 U-Bolt Pipe Clamps sized for OD of Pipe (Again my case = 1 3/8") + 16 extra nuts
6) 16 Washers sized for pipe clamp
7) 1 - Piece of 2" X 2" X 0.062" Thick X 72" Long Aluminum Angle / Cut into 4 17" Long Pieces
8) 8 1/4-20 X 3/4" Long Bolts with nuts and two washers each. (I used Aluminum Rivit Nuts)
9) 2 Stop Collars 1 3/8" ID + clearance to go over pipe with Allen Screw for setting. These are the parts which set the final height of each hose reel and also the bearing surface that the hose reels (bottom hose clamps) swivel upon. You will need 1 stop collar for each hose reel you want to mount. I used some scrap stainless collars from some old mechanical seals.
10) Flat Black Spray Paint
8 comments
May 2, 2012. 11:46 PMrookie1 says:
What a good idea. I really need something like this. Thanks for sharing.
Nov 5, 2009. 10:49 AMamclaussen says:
Good Instructable, after stimulating me enough to finally decide to try to make something like this, but with three services: Air for the tires, water for the pressure washer, and an Electrical heavy duty cord for the tools and the lights; I say thanks for the idea!.
The only thing that would have made me happier, would be an Instructable that could give me more ideas to actually make the reels, because those reels are not easily/affordably available in my country...  Anybody else to the rescue???
amclaussen, Mexico City.
May 9, 2010. 2:37 PMDamian7 says:
 I think you can find a welding shop in Mexico that may do the reels. I don't know if it will be less expensive than buying them but it might be worth it to ask. I believe HomeDepot has stores in Mexico City( I know for sure in Guadalajara and Monterrey) or a local hardware store (ferreteria). Good luck and good idea about air, water and electrical.
Oct 25, 2009. 9:57 PMWeissensteinburg says:
This is awesome. The flexibility reminds me of something you'd find in a factory.
Oct 26, 2009. 5:59 AMunclelar says:
I checked out the Liberty hose reel and I think that the reels you choose to use are much cooler looking than the sainless ones would have looked.
Great job! this will be my new winter project.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Baytonian
