Step 3The Jetski
iImage Information
Removing the screws around the upper deck seperates the deck and hull on the Jetski. The screw heads are hidden with rubber plugs that you just pry up. Inside is a radio box that is secured to the hull bottom, a bunch of colored wires and the screws that hold the motors. Cut the wires leading to the battery box in the seat on the upper cover, leave the wires long. You will need to cut the wires in a few places to remove the motors, leave them long at the motors, so they can be resoldered later. I put a piece of masking tape on each wire to label where they went. Unscrew the motors, radio, antenna and off/on switch. Save the screws, you can use them to remount everything into the duck.
Later, I sealed the hull bottom, and reassembled the empty, motorless jetski with a weight glued in the bottom. It's now a bathtub pushtoy for my grandaughter.
