Duct Tape Backpacking Pack by murple
Contest WinnerFeatured
This is no wimpy school backpack.  This pack can hold everything you need for a week-long backpacking trip for about $25.  Made mainly of duct tape and some PVC pipe it is light weight yet durable.  Making the backpack does take some time, but it's not too difficult.
Materials Needed:
1 - 10ft length of 3/4'' PVC Pipe   ($1.60)
4 - 3/4'' Elbow Connections   ($1.30)
4 - 3/4'' Tee Connections    ($1.30)
3 - 45 Yard Rolls of Industrial Grade Duct Tape   ($18.00)
1 - Can of PVC Pipe Cement    ($2.00)
1 - 2" Buckle   ($2.50)
Optional:
Spray-paint for the frame
Buckles for bag openings
Foam padding for the waist and shoulder straps (The stuff I used was not high-grade, it still works great)
Skills Required:
Very basic PVC bending skills.
Step 1: Cutting and Bending the Pipe
Cut your 10ft length of pipe into sections.
Dimensions
2 x 19cm - lower sides of frame
2 x 24cm - upper sides of frame
6 x 36cm - middle sides of frame and cross pieces of frame
It's not as important to use these exact lengths as it is to make sure the pairs are exactly the same.  Otherwise the frame will be lopsided, and feel funny on your back.
Now take four of the six 36cm lengths, and bend them to your desired angle.  I bent mine with a 5 gallon bucket, but you can use whatever round object you may have.
eHow had a great explanation of how to bend PVC, so I'll include the link to their instructions.        http://www.ehow.com/how_4796089_bend-pvc-pipe.html
My bent lengths are now about 33cm on a straight line from end to end.
AliceWonderStudio says: Mar 27, 2012. 3:32 PM
about how many rolls of tape did you use to make this?
EnigmaMax says: Nov 20, 2011. 4:14 PM
Just curious, how much does this weigh?
rabidsquire2 says: Dec 6, 2010. 1:02 AM
How much weight can it hold and are the straps comfortable enough to wear for long periods of time?
guitarmonk15 says: May 7, 2011. 12:42 PM
weight? dude, if you double over a piece of duct tape, you can pull a 2,000 pound car out of a ditch
yugiohmaster2323 says: May 17, 2011. 5:43 PM
seriously?
guitarmonk15 says: May 19, 2011. 5:28 PM
ya, i'm not being sarcastic. duct tape is really strong
D00M99 says: Sep 2, 2011. 11:17 PM
If you're using the right kind. Don't use the Duck brand duct tape for this kind of stuff; those are designed for decoration, not strength. I recommend Gorilla Duct Tape; I hear it's super strong. Don't duct tape yourself to anything.
yugiohmaster2323 says: Sep 9, 2011. 3:09 PM
yah its really strong
murple (author) says: Dec 6, 2010. 3:27 PM
The straps are quite comfortable, especially with a little padding. As far as weight goes, I loaded it up with about 55 pounds just to test it out, and the backpack handled it just fine.
siafulinux says: Jun 15, 2011. 3:01 PM
How has this held up? Is it something that could be used for a long time (year or more) or would it wear down in a relatively short amount of time?
barry_allen7 says: Jun 9, 2011. 4:36 PM
Wow! Great job! Have you brought it out on any trips? How long did it take to make? Thanks sharing this project!
selstonator says: May 8, 2011. 5:27 AM
Ferguson199 says: May 7, 2011. 1:59 AM
The camouflage ducktape would look awesome I think.
sites23 says: Dec 9, 2010. 7:39 AM
its amazing to know that you can make almost anything with ducktape
ducktape.mac says: Jan 23, 2011. 8:22 AM
you can't make ALMOST anything, you can make ANYTHING. it's like legos, and k'nex.
sites23 says: Feb 11, 2011. 5:59 AM
well you cant make it into an organic substance thats what i meant by ALMOST.
ducktape.mac says: Feb 11, 2011. 12:41 PM
i don't know....
The Sensei says: Dec 1, 2010. 1:53 AM
this is excellent! my only skepticism about this is how it compares to an average backpack in weight. i gotta say tho, its a great application of duck tape; its waterproof, customizable, and easily repairable. very well done =:^b
ducktape.mac says: Jan 23, 2011. 8:23 AM
yea,it doesn't look trashy if you make a patch job with tape!! wait, duck tape never looks trashy.
ducktape.mac says: Jan 23, 2011. 8:21 AM
I CAN'T BELIEVE I CAME ACROSS THIS!!!! i had made an industrial strength duck tape book bag in 5th grade!!! i used it all year, and it stood the test of time. i didn't use pvc, because one, i vowed to ONLY use duck brand duct tape, and never to use any other object for support. but i thought that it was the only one of it's kind, but i never thought someone would make an instructable of it! it looks like yours would work very well, if not better, since it is strengthened with piping. one thing that you could do, is wrap it in camo and brown duck tape. that might give it a woodsy look.
iamlopainus says: Dec 5, 2010. 11:09 AM
This is awesome! Well done.
ReelTym says: Dec 5, 2010. 1:32 AM
Now all you need is a duct tape tent to go with it. ;) See you at the trailhead. - Uncle B
optiblah says: Dec 3, 2010. 7:03 PM
Brilliant! I would only add a thin adjustable buckled strap which goes across the chest and holds the shoulder straps in place. Adds comfort and is easier on the shoulders as the chest carries some of the weight then.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
