loading
loading
Picture of Duct Tape Milk Carton Planters
Why buy new planters like a sucker when you can quickly make a more adorable ones from milk cartons and duct tape?
The combination of a water proof carton and strong duct tape make these pots durable enough to use inside as well as outdoors.
Materials
Milk Carton
Duct Tape - Gray, Black, White, Green, Yellow, Red
Parchment Paper
Tools
Scissors
Pencil
Stencils (optional)
Step 1: Cut Milk Carton
Picture of Cut Milk Carton
Get your milk carton (Half gallon or quart) and decide how tall you want your planter to be.
  • Cut the top off the milk carton
  • Unfold top piece
  • Remove plastic spout
Step 2: Cover Carton
Picture of Cover Carton
Cover carton in two layers of duct tape.
Cut two 1/4" holes on opposite sides of the bottom of the carton.
To ensure proper drainage, when you are ready to plant, fill with gravel up past these holes.  This will also prevent soil from running out.
Step 3: Create Bottom Tray
The top of the carton is used to create the bottom tray for the planter.
  • Cut the top piece in half
  • Lay out side to side
  • Tape the two pieces together
  • Place carton on top of piece to determine size - Allow about a 1/2" all around to be turned up to make the sides
  • Cover piece entirely in duct tape and fold up sides
  • Make a 1/2" diagonal cut in each corner
  • Cut out corners
  • Bend sides
  • Tape sides together
Step 4: Decorate!
Now the fun part!
Using parchment paper allows you to create all kinds of duct tape stickers.  You can make intricate designs without getting tape stuck all over the place or having it fold up on itself.
  • Stick duct tape to parchment paper
  • Turn over and using a pencil, outline whatever design you like. You can use a homemade template from graph paper, a stencil or just freehand drawings
  • Cut out designs
  • Remove duct tape from parchment
  • Affix your new decorations to the carton
Fill your personalized pots with plants and flowers.
HeatherP21 month ago
I want to make these! Too bad I already planted...
sparkleponytx3 months ago
Love this idea! And making the stickers from duct tape is so clever!
Thanks for sharing your adventures with duct tape. I have used it at times to tape planters that were cracked with a ring around the top when I had a bunch of transplants to do. Shows a feeling of conquering a project and doing what works and is available.
wilgubeast4 years ago
These duct tape planters look great.
