This is not a good rc project for beginners. I just wanted to see if this could be done.
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
However I can tell you about any part of it. What do you mean "circuit out of the plane"? I'm not sure what you're looking for.
For what it's worth, I recommend flying wings from Crash Test Hobby for beginners. I have an assassin and a reaper, and they're both great.
thank You...
What I was saying is that some countries have varying laws regarding if/where/how you can use r/c equipment, so make sure you know and follow the rules where you live. (For instance where I live, there are certain places where one can and cannot legally fly r/c planes. It's good to know where these places are, and visit with people who already fly as you get yourself into the r/c hobby.)
Check in local shops, search the internet, and ask around. If you cannot find local dealers for radio control components, you can order things online. Hobby King ships worldwide out of China, and has very good prices. Be sure to check your laws regarding the radio control hobby where you live before you purchase anything. I hope this helped!
OR DO YOU ATTACH THE SPEED CONNTROL TO A RECEIVER ALONG WITH THE SERVOS AND BATTERY
Try one of these or something similar (I have the assassin)
This is the radio I have.
I concur, it's definitely a rush see your own creations fly!
And the motor that you are using there is too big for it. As far as I can see from the image, you use a motor that uses 9x4 and 1300 mA battery. Hmm. It is really creative. But erhm. I think the "foam" is not the right material for this kinda plane - "Zagi". I think balsa wood would be much more proper.
The layout for the wing base and all the ribs to step 1. I also added a bit to step 7 about the CG, which you should know if you do build this.
I don't mention a lot about the elevons, but they should be about 16 1/2" long. Mine are about 3" at the wing tip end, and about 2" on the narrower end. They were cut at 45 degrees on the bottom of the hinge edge so they can move up and down easily.
Hope all this helps. Let me know if you build one. I'd love to hear about it.
Your project looks like huge fun.
Yep, I was surprised it flew so well too. The final weight was 24 oz. even, and I'm flying at almost exactly 5280 ft. above sea level. I added another step at the end with info on all the radio gear.
That wing has got some lift to overcome the weight of the duct tape, nice!
