Duct Tape Rockets
Duct Tape Rockets
  • last photo ←
How to put duct tape into orbit for a dollar a day.
Step 1Build Your Launcher
Build Your Launcher
The launcher is made out of PVC. I used what I had around. It has 2 parts: an air tank, and a launch pipe.
The air tank is used because most valve stems don't let a large volume of air through at a time. The valve stem let the air in, but not out (duh!). The first time I made this, I cut apart i bike inner tube for the stem, drilled a hole in the end cap, and hot melt glued it together. That lasted all of 10 launches. Then I found car tire valve stems at the local hardware store, so use those. Just follow the instructions on the package to drill the right size hole.
The launch pipe carries the air from the air tank into the rocket. Mine is way longer than it needed to be, but then again, I planed on make some much bigger rockets latter :) (don't, unless you have somewhere far from any cars that can be damaged. the big one I made with a Nerf ball nose but a big dent I the neighbor's car, luckily he was a good sport.) It does help you not have your ear next to the end of the pipe, and thats very good considering how loud this is. The launch pipe is 1/2" water pipe. The rockets should fit snug on it, and are fed completely onto it before launch.
I later added a threaded fitting below the valve so I could take the launcher apart for storage. If you do, use Teflon tape so that it doesn't leak.
20 comments
Jan 16, 2010. 12:57 PMMadrias357 says:
These are really quite cool!  I remember when I was a little younger, my friends and I would make stuff like this and shoot it off for the 4th of July.  Drove our neighbors mad with poorly constructed rocket tubes and rockets that we'd launch, of course, down the street.  One of them threatened to call the cops if we did it again, so we 'accidentally' shot his car with one.
May 22, 2009. 4:28 PMaheld says:
For what its worth - we discovered today that lighter/smaller rockets go better with lower pressures (20-40 lbs). Our larger efforts would go best from 50-80 pounds. Unless the rocket is solidly wrapped in duct tape, pressures over about 90 psi often resulted in exploded rockets.
May 25, 2009. 1:07 PMaheld says:
Yep - it doesn't take them long to try everything, does it? It also makes a heck of a POP! when you have 80-100 lbs air loaded in. We had one blow into two sections, and both still launched successfully (momentum, I guess.)
May 8, 2009. 4:02 PMaheld says:
Amazing! For $18 worth of pvc, connectors and a valve it works perfectly! Built it in less than 2 hours, including the trip to the hardware store. Used my portable air compressor. This was unquestionably our most popular Tech Club meeting of the year. THANK YOU!
Sep 19, 2008. 11:40 AMtodroda says:
Thanks for the ideas!
launch 2Launch 1Love the rocket. We have built two. First was all 1/2 inch pipe with a manual release valve. works good up to 115 PSI. Decided to give it away.
Second is 3/4" PVC with two launch tubes, an installed pressure gauge (safety for the kids) since we use a bicycle pump to fill, and a yard sprinkler electric launch valve. It has two launch pipes. 1/2" and 1". we have only used this one a few times and only up to 110 PSI. works great with the electric launch control as the hand valve some kids turned too slow.
launch height has been agreed by several was about 5 stories high.
Masking tape rocket with waxy magazine pages as the paper and a little duct tape on the nost seem to work the best so far.
Mar 3, 2008. 6:07 PMultrauber says:
how high do these go?
Aug 14, 2007. 9:28 PMoinkoinkzoopals says:
i made one of these in tech ed class this year ecsept we used masking tape
Jun 19, 2007. 3:57 PMe1337 says:
Ive been makeing these things for years, Ive discovered that the tighter the rocket is the higher it goes. The only problem is they can only be use once cause i cant put the back on the launcher (the inside is screwed up). So i make them with the blue painters tape and only one sheet of paper.
Jun 17, 2007. 4:52 PMknexer1 says:
I just roll up old papers from school, 6-7 sheets makes a pretty nice rocket.
Jun 14, 2007. 6:56 PMwestfw says:
A nice enhancement of the "Straw rockets" I've seen elsewhere (OMSI?)
Jun 14, 2007. 4:40 PMjoemonkey says:
oh. i thought they used engines. cool, but not that powerful.
Jun 14, 2007. 6:29 PMjoemonkey says:
thats cool. my boyscout leader had one like it. these must be better. sorry about the down talk. his go MAYBE 50 ft up. we had to pump a bike pump untill it killed our arms to get it that high. it sucked! we all hated it after a while so we drilled holes all thru it and put gas in it.we lit a match and started pumpin. 3 seconds later it would shoot fire out the little holes. :D
Jul 16, 2008. 12:29 PMorangesrhyme says:
That's pretty sweet. Does it look like a green tracer round?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:pleasedontspamme
