Introduction: Duct Tape Wallet
About: Happiness can be found in even the darkest of times, if one only remembers to turn on the light ~J.K.R.
Hi, in this tutorial I will be showing you how to make an adorable duct tape wallet with 6 credit card holders, a bifold, and 2 hidden pockets! This took me about half an hour so set aside some time for this great project.
Step 1: Materials
For this tutorial you will need
  • X-Acto Knife
  • Two Rolls of Duct Tape
  • Cardboard or Cutting Mat
  • Measuring Tape
Step 2: Strips #1
Take your measuring tape and get 4 eight inch strips of your main color of duct tape.
Step 3: Overlap
Take 2 of your strips and overlap them so that the height is 3 inches. Once you have done this with the 4 strips lay them sticky side on sticky side so that it creates a sheet. Repeat once more.
Step 4: Bifold
Take 4 inches of tape and cut it in half. Place both of your strips on top of each other and place both strips at the bottom and crease so you will have a book like thingy.
Step 5: Strips #2
Cut 2 seven inch strips and overlap them so that the height of the strips together is 3 inches tall. Put one on top of the other stickyside on stickyside. Cut this sheet in half.
Step 6: Card Holders
Measure out 3 seven inch strips of your secondary color. Cut these in half at 3 1/2 inches. Repeat this step for your main color too.
Step 7: Pockets and Card Holders
Take your secondary color and tape the rectangle onto one of your pocket squares. Next go slightly down and tape on a rectangle of your main color an tape it down. Lastly take your secondary color and tape it onto the bottom. Repeat this for the other square and the rectangles. Tape both of your newly attached squares and tape them both on 3 of the four sides (NOT IN THE MIDDLE).
Step 8: !!!!!VIOLA!!!!!
TADA ! Now you have created a gorgeous duct tape wallet!
