Materials:
- Five 10' long, 3/4" Outer Diameter PVC pipes
- Hacksaw
- Scissors
- Tape measure
- Two or three large trash bags
- 2x4 wood plank between 3' and 4' in length (or similar) for the seat
- 3 rolls of Scotch Brand Tough Duct Tape (make sure it says waterproof on the label!)
- Lighter (optional: used for easier PVC bending)
- 3 square feet cardboard (optional : used to make paddle)
Remove these ads by
Signing UpStep 1: The First Cut
Cut two 4" lengths of PVC from the same 2' pipe. Make a cut 2" deep into each of these pipes lengthwise, and bend the wings back until they create an angle approximately 60º with each other. These braces are essential to give the kayak its tapered shape. Note : hold lighter under the area of the pipe you wish to bend in order to soften the PVC first.
Visit Our Store »
Go Pro Today »
This is very cool though and I wish everyone lots of luck on your projects. =^-^=
I should change my nick to "CheapRat" hehe
Good Luck on you project , can't wait to see it published in the featured section!!!
http://gaboats.com/construction/
I've seen canoes and small water craft made from just about anything that you can make a water tite seal out off. Including duct tape before.
It's not a new idea but that doesn't a take away from the fact you tried it and were successfull at building a small water craft for a low cost.
Next - just as a suggestion you might want to move up to a folding plywood dingy type craft - they too can be built very cheaply - you sew them together, seal the edges and use a water proof cloth for the ends. You fold it up when not in use.
A single sheet of 1/4 inch ply will do. I have the plans for one if you care to try it. you're welcome to them or i'm sure you can find a instructable or the plans and make an instrucable for the build yourself.
again nice job on this one. looks to be a simple repair if you spring a leak!
Look forward to seeing future builds and what you come up with...
chase
For those who want to use this as a quick and dirty form for a fiberglass version, Fiberglass, tends not to be as flexible as Carbon Fiber, and the Polyethylene resin usually used for fiberglass, breaks down in sunlight so you might want to put a Gel Coat over it to protect it. FiberJute, is more ecofreindly, although the resin is still probably toxic. Essentially to use fiberjute, you use a jute mat instead of glass or carbon fiber mat. My father tried to make Burlap walls, and as far as I know the Burlap he used, was a form of cloth made from Jute, so if you can find Jute fiber burlap, it might make a good matting. (There is a car being built from it here in Canada).
Don't forget that you can create a more lively kayak if you make it a bit bigger and build in some ballast along the bottom. I once reballasted my fathers canoe, (and rebuilt the floatation cells) and turned it into a much safer vehicle, my father had found it "Tippy" when he tried to sit up with his trick leg forward.
Great advice on the fiberglass, thanks!
just a question re waterproofing (having first-hand experience how not-so-much duct tape), but would it work to smear fibreglass over the outside? you can buy it at the hardware store.
the only thing i'm thinking is that fibreglass works wierd with other substances so i dunno if it would reinforce/seal the duct tape or eat it for lunch.
Involved, messy and not applicable to just any surface.
Anyway, check out skinning your frame with Dacron.Glue it on then heat shrink it for a tight fit. Still not puncture resistant, but no seams to leak.
Great idea BTW. Good job!
That's why as you put in a heavier person, it rides lower. The Styrofoam, while light actually adds a little weight. However, its a good idea in case you Kayak fills with water it won't sink to the bottom.
I like it alot....
Next time they start reusing Alcatraz Island Prison or in the Movie "Escape from New York/LA" using Manhattan Island or after the great earthquake that seporates Lower Califoria from the rest of the USA as a future prison locations.
I know what I'm using as a great escape device.
No metal parts and floats nicely.
I think I'll even modify it maker it bigger with twin side pontoons for better stablity in rougher ocean waters.
I might even put up a PVC Mast for attaching a sail cloth for working smarter not harder to let the wind work for me.
But I need to study the best profile and matterial for making a stealth sail for sailling undetected still.
There's no room for baggage, right?
Oh, and 2" is about 50mm, J.
I wonder if I could make a real boat this way... :)
Thanks!
That's pretty spiffy!!
I'm not into kayaking, but your directions read clear and the pictures are clear and accent the instructions perfectly.
I could easily modify this to make a small boat for the local lake.
That is super cool DIY stuff
Thx for posting this
Greetings from Belgium
Erik
If you spent a little more time on enjoying the instructables instead of finding ways to correct people in almost every single post you make you'd have realized what it was for.
And as far as your comment about no difference in different brands, you have no idea what you are talking about. Please do some research on the different brands of duct tape and how they are made. There are higher quality tapes, stitching, reinforcing and adhesives are all different. If you can't swim, the difference in tape used could mean your life. So in the "grand scheme of things" there are some that make a significant difference.
You state I try to find ways to correct people in almost every single post I make, and you have followed several of my posts to make disparaging comments. That is an inaccurate statement (I have periodically reviewed my comments, and the majority are supportive and congratulatory); but I assume I have corrected some statement of yours in the past and so you have a personal vendetta. Cest la vie - it simply provides me a bit of amusement! Please carry on! ;)
