You have a hole in a tire that has an inner tube? This instructable shows an easy and quick repair until you can get the tire replaced. Remember that this is for ONLY TIRES WITH INNER TUBES AND ARE NOT CRITICAL.
Remove these ads by
Signing UpStep 1Clean and prep area.
Disassemble the tire and remove from rim.
Wipe the interior of the tire with a dry shop cloth and vacuum the dust out.
Wipe the area around the hole with denatured alcohol and allow to dry.
Cut 4 pieces of Duct Tape.
1. There is NO reason to replace the tube as the damage is in the tire casing sidewall [in the FIRST photo, note the INFLATED, undamaged inner tube bulging through the hole in the sidewall].
2. The vehicle upon which this repaired tire is used is NOT a street or highway vehicle, but instead a lawn/garden cart.
3. This repaired tire will NOT be used at high speed [actually usually not greater than walking speed!].
4. The ONLY reason for this repair is to PROTECT the exposed inner tube from damage from chaffing in the hole of the tire casing, AND from contact with sharp or damaging objects.
5. Therefore, the repair demonstrated in this instructable, or anything [even a piece of plastic taped inside the tire casing will protect the tube, AND BE SAFE to use.
2. the more reason to put a new tyre. Catch a sharp rock and say goodbye to the tube and the tyre, and if the garden's wet, the glue of the duct tape will peel off
3. agree
4. better putting duct tape inside the tyre better than the tube itself, this way won't protect anything
5. is not safe at all
as emergency repair is ok, but is not safe anyway
Using this on a car would be stupid but at 10mph.
Nice.
