Duct tape laptop skin by hummer_head
Contest WinnerFeatured
When you have a laptop the concept of portability means scratches and bruses. When they become more obvious than the laptop's logo it's getting a llittle bit ugly. When this happens it's time get a skin or why not make a skin? I had already a skin on the laptop but it was an year old - i needed a change. So this is what i came up with.
mommysdarkside3 says: Apr 4, 2012. 10:49 AM
just giving a sugestion.... if you do not want to stick the duct tape on ur computer u can make a sheet of duct tape and then cover the other side in duct tape so it isnt sticky and make it to fit ur computer and then just slide it over
danlynne07 says: Nov 26, 2012. 12:27 PM
i love that idea thank you.
justanado says: Dec 20, 2011. 11:36 PM
Hey! Love your ible, but i was just wondering, would it be easy to peel off the laptop afterwards?
ssgtgibby says: Jul 18, 2012. 12:13 AM
I think it shouldn't be hard to get it off.. if it's sticky use some goo gone or rubbing alcohol
hummer_head (author) says: Dec 21, 2011. 12:49 PM
Easy -yes, sticky - of course :)
CookieMonstah123 says: Feb 20, 2012. 5:11 PM
Lolz..... Not To Be Rude But I Know That Mostly Gurls Like Zebra Print And So I WAzx Wonderin If Dis WAzx Ur Laptop However This Is So Awesome! I Love Zebra Print And I Come FRom A Wealthy Family so I Basically Live In a Zebra room Because Myh Parents Can Afford All The EXpensive Zebra Stuff I Think Itsz Awesome....And DOnt Take This as A stereotype comment because i respect the instructables rules ! :) Ur SO CReative And Awesome .....Thanks For Being Here For Ideas!
soilman89 says: Dec 25, 2010. 7:43 AM
try making various types of skin
Tommy Jae says: Nov 12, 2010. 6:03 PM
Umm..... Are you sure that's DUCT tape? Looks more like electrical tape; duct tape is usually wider in its original size, is a lot more stringy and has a lot more adhesive gunk that quickly melts off with even moderately high temperatures.
I do believe you have to actually use Duct tape to enter the Duct tape contest. But that's just me. Anywho, other than that it's pretty cool and I'd never be able to make it look that good. Kudos to you.
vee-man.mol says: Dec 20, 2010. 4:39 PM
i saw that to :)
hummer_head (author) says: Nov 13, 2010. 8:06 AM
I know that's not the duct tape that you are used to see, but i'm from Bulgaria and that is what i have here. The wider colored duct tape isn't easy to find.
mommysdarkside3 says: Apr 4, 2012. 10:44 AM
hey is this a skin or did u just wrap ur screen in duct tape?
slu6alka says: Nov 30, 2010. 12:32 PM
Ne e zle ima6 1 glas ot men :P
hummer_head (author) says: Nov 30, 2010. 12:42 PM
6te se revan6iram:)
dnorm says: Nov 18, 2010. 7:26 PM
from Wikipedia (Zebra / Stripes)... comes this info... 'It was previously believed that zebras were white animals with black stripes, since some zebras have white underbellies. Embryological evidence, however, shows that the animal's background color is black and the white stripes and bellies are additions.[1]'
my guess was wrong... yours was right...
Broom says: Nov 21, 2010. 11:49 AM
They did an experiment where they asked children this question. Not surprisingly: white children tended to say "white with black stripes"; black children "black with white stripes".
The embryological evidence is a neat tack, since zebes are actually 50/50...
hummer_head (author) says: Nov 18, 2010. 11:02 PM
So i was right that was tough question! Cool hhaha! Thanks by the way:)
katerlyn says: Nov 12, 2010. 10:11 AM
I saw leopard brown and black duct tape in walmart last night. 8-)
hummer_head (author) says: Nov 13, 2010. 8:07 AM
Go for it :)
xPiixaaa says: Nov 12, 2010. 3:19 PM
niceeee ill try it :) thnx!!
confusias says: Nov 11, 2010. 12:02 PM
I think I would add clear tape or a clear coat of something to keep the duct tape from peeling up. My wife makes bags and wallets out of duct tape and they get a dirty look when the edges of the tape peel up and collect dust. Awesome job though! My wife would love it. Maybe a pirate design though.. hehe.
hummer_head (author) says: Nov 11, 2010. 12:37 PM
Thanks for the advise
ckirkwood9 says: Nov 11, 2010. 9:31 AM
i've had issues with laptops overheating... (and causing the processor to loose contact with the motherboard) also with fans not doing their job.... i wonder if this will add to the heat-factor?
Granted the majority of the heat is in the base, not the screen... BUT i wonder how much (if at all) the temp will be affected. If you go into the bios on some laptops, there's a 'temperature' screen to tell you the current running temp. I'd be curios to see it before/after this hack.
bpfh says: Nov 11, 2010. 12:26 PM
There will be no difference in the heat dissipation. The heat sensors are (rightly so) installed under the CPU for the CPU temp, and if you have any others hanging around they will be :
- On the mainboard for ambiant system temp
- In the hard disk drives
- Under the graphics card central processor (GPU)
Those will monitor the main system component temperatures.
Now, there is not a lot of heat in the screen. Yes, the LCD panel does give off heat, but in negligible amounts. The screen illumination is either a cold cathode tube (tubes) on the top/bottom/both edges of the screen, or an array of LEDs, depending on make and model.
Having a cover on the screen will of course affect the screen heat dissipation, probably by a degree centigrade, but not by much more, as the active face of the display is already dissipating most of the heat anyway
pinkpurlknits says: Nov 11, 2010. 10:19 AM
The screen is not where the overheating is occurring,it is happening in bottom part of the laptop. It is not a problem to do this. Sounds like your machine is dirty, can lead to fans not working properly and is the most common reason for overheating.
hummer_head (author) says: Nov 11, 2010. 9:44 AM
I'm not sure that the black light behind the screen has something to do with the cpu's temp but now its too late to check the bios because i've never checked the before temp. I don't remember feeling heat on the top of the laptop at all, neither now.
Ebby1 says: Nov 10, 2010. 3:21 AM
Love it! I'm going to give this one a whirl. Maybe i'll try cheeta though! Thanks :)
hummer_head (author) says: Nov 10, 2010. 3:37 AM
Thanks! Glad you like it! Post a picture to see it after you make it.
ElvenChild says: Nov 11, 2010. 10:51 AM
make a lion for upcoming os x lion
lindaoak says: Nov 11, 2010. 10:07 AM
Great idea, but one question: For those of us sensitive to the plastic smell, would duct tape cause even more odors when hot?
mman1506 says: Nov 11, 2010. 10:12 AM
the screen wont get hot for any working coputer the backlight is too small
cameronhirsch says: Nov 11, 2010. 9:39 AM
Looks great, but they sell zebra stripe duck brand tape here. Does give me some good ideas though.
Opcom says: Nov 11, 2010. 8:54 AM
I like it but I am always concerned about the duct tape glue seeping out and it is very sticky and messy.
hummer_head (author) says: Nov 11, 2010. 9:05 AM
i'm not a pessimist и enjoy the moment :)
Ted1491 says: Nov 11, 2010. 8:33 AM
A little Zebra and some large band Aids, a little bit camo spray paint a couple of 14 gage wires hanging out and you never have to worry about anybody stealing it.
Nicholin says: Nov 11, 2010. 6:52 AM
I would like to see how you wrapped the edges; where you stopped the tape on the sides, front and how you did the areas around the hinges. This is a nifty idea, but if you added a bit more detail for those of us who are OCD about the little things, that would be great.
hummer_head (author) says: Nov 11, 2010. 7:56 AM
My camera isn't with me right now. i'll post pictures asap.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
