3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dual Motor Driver with Arduino using a SN754410NE Quad Half H-Bridge
A step by step project guide by ArduinoFun
With this Instructable I am going to show you how to use a SN754410NE Quad H-Bridge IC to control two 12 volt DC Motors.
I have added a video so that you can see the Dual Motor in action.  As you can see in the video, all the wires can be a little confusing to look at.  To make things easier to view and understand as we go along, I have also created an illustration for you to refer to.  You may also download a printable PDF file of this illustration.  I have depicted an Arduino board in the illustration, if you already have one you are good to go, if not... you can do like I have and Build Your Own Arduino following another one of my instructables.
Breadboard Illustration - You may also download a printable PDF file of this illustration
Duel Motor H-Bridge Setup
Step 1Parts List
Parts List
Here is the recommended parts you will need in order to complete this project. I have provided sources where you can purchase items from and their prices.  These parts are available at others sites as well.
  1. Arduino board - $29.95 at CuriousInventor.com or...
  2. Build Your Own Arduino - Total build cost $15.95 at ArduinoFun.com
  3. SN754410 Quad Half H-Bridge - $2.50 available at ArduinoFun.com
  4. 840 Tie Point Breadboard - $6.95 available at ArduinoFun.com
  5. Wire Jumper Kit - $12.95 available at ArduinoFun.com
  6. Two DC Motors - $3.99 ea. available at ArduinoFun.com
DISCOUNT: 10% OFF Your Total Order at ArduinoFun.com when you use coupon code "INSTRUCTABLES" at time of checkout.
6 comments
May 8, 2010. 1:12 PMoshondrom says:
 This is stupid!Jou coud use just 2 digial pins 2 transistors and no other chips!
Mar 18, 2012. 8:27 AMsupercapacitor says:
oshondrom,
1) You obviously don't understand the purpose of an H-bridge.
2) You are wrong, you could not drive the motors depicted in AruinoFun's instructable with only 2 transistors. Trying to do so would put strain on the arduino board. Even then, the arduino does not source enough current to fully saturate a high current MOSFET w/o preamp transistors .
3) "This is stupid!" violates the "be nice" policy...
Jan 2, 2012. 4:54 PMbdughi says:
Your links to the diagrams are dead. other than that you have a good instrucable. your code is good and simple.
Sep 6, 2010. 6:25 PMhughligen says:
I'm confused as to why you have in the parts list, the Arduino as well as the build your own arduino.
Is it a choice? as in either a off the shelf arduino or a homebuilt one?
Jul 7, 2010. 8:15 PMjohnnyhellfire says:
So can you control the direction the motors go or is it only single directional circute
Feb 7, 2010. 5:49 AMamando96 says:
 I really don't understand anything of your code.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:ArduinoFun
