3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Laser Tag - Duino Tag
Step 8The Code
The Code
Code Notes:
I am not going to go into much detail about how the code works hopefully the fairly extensive comments provided in the code will be enough to explain it, if not the there are already good tutorials out there.
Limitations:
The code only works is set up in a way that it can only do one thing at a time and until the dual core arduino is easiest just to cope with that.
This means when one tagger is shooting it will not notice if it gets shot/tagged.  You could complicate the code by using interrupts , but in the real world it is not really a big problem, the shooting or getting shot happen so quickly that they very rarely interfere with each other.
In future iterations of the code I will probably make it so that the tagger checks to see if it has been tagged in-between each bit it transmits, making it very very unlikely that it would miss an incoming message (hit / tag). I have played a few games using this code and similar code and it seems to work well.
//      Start of code (copy and paste into arduino sketch)
//                       Duino Tag release V1.01
//          Laser Tag for the arduino based on the Miles Tag Protocol.
//           By J44industries:     www.J44industries.blogspot.com
// For information on building your own Duino Tagger go to: http://www.instructables.com/member/j44/
// Much credit deserves to go to Duane O'Brien if it had not been for the excellent Duino Tag tutorials he wrote I would have never been able to write this code.
// Duane's tutorials are highly recommended reading in order to gain a better understanding of the arduino and IR communication. See his site http://aterribleidea.com/duino-tag-resources/
// This code sets out the basics for arduino based laser tag system and tries to stick to the miles tag protocol where possible.
// Miles Tag details: http://www.lasertagparts.com/mtdesign.htm
// There is much scope for expanding the capabilities of this system, and hopefully the game will continue to evolve for some time to come.
// Licence: Attribution Share Alike: Give credit where credit is due, but you can do what you like with the code.
// If you have code improvements or additions please go to http://duinotag.blogspot.com
// Digital IO's
int triggerPin             = 3;      // Push button for primary fire. Low = pressed
int trigger2Pin            = 13;     // Push button for secondary fire. Low = pressed
int speakerPin             = 4;      // Direct output to piezo sounder/speaker
int audioPin               = 9;      // Audio Trigger. Can be used to set off sounds recorded in the kind of electronics you can get in greetings card that play a custom message.
int lifePin                = 6;      // An analogue output (PWM) level corresponds to remaining life. Use PWM pin: 3,5,6,9,10 or 11. Can be used to drive LED bar graphs. eg LM3914N
int ammoPin                = 5;      // An analogue output (PWM) level corresponds to remaining ammunition. Use PWM pin: 3,5,6,9,10 or 11.
int hitPin                 = 7;      // LED output pin used to indicate when the player has been hit.
int IRtransmitPin          = 2;      // Primary fire mode IR transmitter pin: Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!! More info: http://j44industries.blogspot.com/2009/09/arduino-frequency-generation.html#more
int IRtransmit2Pin         = 8;      // Secondary fire mode IR transmitter pin:  Use pins 2,4,7,8,12 or 13. DO NOT USE PWM pins!!
int IRreceivePin           = 12;     // The pin that incoming IR signals are read from
int IRreceive2Pin          = 11;     // Allows for checking external sensors are attached as well as distinguishing between sensor locations (eg spotting head shots)
// Minimum gun requirements: trigger, receiver, IR led, hit LED.
// Player and Game details
int myTeamID               = 1;      // 1-7 (0 = system message)
int myPlayerID             = 5;      // Player ID
int myGameID               = 0;      // Interprited by configureGane subroutine; allows for quick change of game types.
int myWeaponID             = 0;      // Deffined by gameType and configureGame subroutine.
int myWeaponHP             = 0;      // Deffined by gameType and configureGame subroutine.
int maxAmmo                = 0;      // Deffined by gameType and configureGame subroutine.
int maxLife                = 0;      // Deffined by gameType and configureGame subroutine.
int automatic              = 0;      // Deffined by gameType and configureGame subroutine. Automatic fire 0 = Semi Auto, 1 = Fully Auto.
int automatic2             = 0;      // Deffined by gameType and configureGame subroutine. Secondary fire auto?
//Incoming signal Details
int received[18];                    // Received data: received[0] = which sensor, received[1] - [17] byte1 byte2 parity (Miles Tag structure)
int check                  = 0;      // Variable used in parity checking
// Stats
int ammo                   = 0;      // Current ammunition
int life                   = 0;      // Current life
// Code Variables
int timeOut                = 0;      // Deffined in frequencyCalculations (IRpulse + 50)
int FIRE                   = 0;      // 0 = don't fire, 1 = Primary Fire, 2 = Secondary Fire
int TR                     = 0;      // Trigger Reading
int LTR                    = 0;      // Last Trigger Reading
int T2R                    = 0;      // Trigger 2 Reading (For secondary fire)
int LT2R                   = 0;      // Last Trigger 2 Reading (For secondary fire)
// Signal Properties
int IRpulse                = 600;    // Basic pulse duration of 600uS MilesTag standard 4*IRpulse for header bit, 2*IRpulse for 1, 1*IRpulse for 0.
int IRfrequency            = 38;     // Frequency in kHz Standard values are: 38kHz, 40kHz. Choose dependant on your receiver characteristics
int IRt                    = 0;      // LED on time to give correct transmission frequency, calculated in setup.
int IRpulses               = 0;      // Number of oscillations needed to make a full IRpulse, calculated in setup.
int header                 = 4;      // Header lenght in pulses. 4 = Miles tag standard
int maxSPS                 = 10;     // Maximum Shots Per Seconds. Not yet used.
int TBS                    = 0;      // Time between shots. Not yet used.
// Transmission data
int byte1[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int byte2[8];                        // String for storing byte1 of the data which gets transmitted when the player fires.
int myParity               = 0;      // String for storing parity of the data which gets transmitted when the player fires.
// Received data
int memory                 = 10;     // Number of signals to be recorded: Allows for the game data to be reviewed after the game, no provision for transmitting / accessing it yet though.
int hitNo                  = 0;      // Hit number
// Byte1
int player[10];                      // Array must be as large as memory
int team[10];                        // Array must be as large as memory
// Byte2
int weapon[10];                      // Array must be as large as memory
int hp[10];                          // Array must be as large as memory
int parity[10];                      // Array must be as large as memory
void setup() {
  // Serial coms set up to help with debugging.
  Serial.begin(9600);
  Serial.println("Startup...");
  // Pin declarations
  pinMode(triggerPin, INPUT);
  pinMode(trigger2Pin, INPUT);
  pinMode(speakerPin, OUTPUT);
  pinMode(audioPin, OUTPUT);
  pinMode(lifePin, OUTPUT);
  pinMode(ammoPin, OUTPUT);
  pinMode(hitPin, OUTPUT);
  pinMode(IRtransmitPin, OUTPUT);
  pinMode(IRtransmit2Pin, OUTPUT);
  pinMode(IRreceivePin, INPUT);
  pinMode(IRreceive2Pin, INPUT);
  frequencyCalculations();   // Calculates pulse lengths etc for desired frequency
  configureGame();           // Look up and configure game details
  tagCode();                 // Based on game details etc works out the data that will be transmitted when a shot is fired
  digitalWrite(triggerPin, HIGH);      // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  digitalWrite(trigger2Pin, HIGH);     // Not really needed if your circuit has the correct pull up resistors already but doesn't harm
  for (int i = 1;i < 254;i++) { // Loop plays start up noise
    analogWrite(ammoPin, i);
    playTone((3000-9*i), 2);
  // Next 4 lines initialise the display LEDs
  analogWrite(ammoPin, ((int) ammo));
  analogWrite(lifePin, ((int) life));
  lifeDisplay();
  ammoDisplay();
  Serial.println("Ready....");
// Main loop most of the code is in the sub routines
void loop(){
  receiveIR();
  if(FIRE != 0){
    shoot();
    ammoDisplay();
  triggers();
// SUB ROUTINES
void ammoDisplay() { // Updates Ammo LED output
  float ammoF;
  ammoF = (260/maxAmmo) * ammo;
  if(ammoF <= 0){ammoF = 0;}
  if(ammoF > 255){ammoF = 255;}
  analogWrite(ammoPin, ((int) ammoF));
void lifeDisplay() { // Updates Ammo LED output
  float lifeF;
  lifeF = (260/maxLife) * life;
  if(lifeF <= 0){lifeF = 0;}
  if(lifeF > 255){lifeF = 255;}
  analogWrite(lifePin, ((int) lifeF));
void receiveIR() { // Void checks for an incoming signal and decodes it if it sees one.
  int error = 0;
  if(digitalRead(IRreceivePin) == LOW){    // If the receive pin is low a signal is being received.
    digitalWrite(hitPin,HIGH);
    if(digitalRead(IRreceive2Pin) == LOW){ // Is the incoming signal being received by the head sensors?
      received[0] = 1;
    else{
      received[0] = 0;
    while(digitalRead(IRreceivePin) == LOW){
    for(int i = 1; i <= 17; i++) {                        // Repeats several times to make sure the whole signal has been received
      received[i] = pulseIn(IRreceivePin, LOW, timeOut);  // pulseIn command waits for a pulse and then records its duration in microseconds.
    Serial.print("sensor: ");                            // Prints if it was a head shot or not.
    Serial.print(received[0]);
    Serial.print("...");
    for(int i = 1; i <= 17; i++) {  // Looks at each one of the received pulses
      int receivedTemp[18];
      receivedTemp[i] = 2;
      if(received[i] > (IRpulse - 200) &&  received[i] < (IRpulse + 200)) {receivedTemp[i] = 0;}                      // Works out from the pulse length if it was a data 1 or 0 that was received writes result to receivedTemp string
      if(received[i] > (IRpulse + IRpulse - 200) &&  received[i] < (IRpulse + IRpulse + 200)) {receivedTemp[i] = 1;}  // Works out from the pulse length if it was a data 1 or 0 that was received
      received[i] = 3;                   // Wipes raw received data
      received[i] = receivedTemp[i];     // Inputs interpreted data
      Serial.print(" ");
      Serial.print(received[i]);         // Print interpreted data results
    Serial.println("");                  // New line to tidy up printed results
    // Parity Check. Was the data received a valid signal?
    check = 0;
    for(int i = 1; i <= 16; i++) {
      if(received[i] == 1){check = check + 1;}
      if(received[i] == 2){error = 1;}
    // Serial.println(check);
    check = check >> 0 & B1;
    if(check != received[17]){error = 1;}
    if(error == 0){Serial.println("Valid Signal");}
    else{Serial.println("ERROR");}
    if(error == 0){interpritReceived();}
    digitalWrite(hitPin,LOW);
void interpritReceived(){  // After a message has been received by the ReceiveIR subroutine this subroutine decidedes how it should react to the data
  if(hitNo == memory){hitNo = 0;} // hitNo sorts out where the data should be stored if statement means old data gets overwritten if too much is received
  team[hitNo] = 0;
  player[hitNo] = 0;
  weapon[hitNo] = 0;
  hp[hitNo] = 0;
  // Next few lines Effectivly converts the binary data into decimal
  // Im sure there must be a much more efficient way of doing this
  if(received[1] == 1){team[hitNo] = team[hitNo] + 4;}
  if(received[2] == 1){team[hitNo] = team[hitNo] + 2;}
  if(received[3] == 1){team[hitNo] = team[hitNo] + 1;}
  if(received[4] == 1){player[hitNo] = player[hitNo] + 16;}
  if(received[5] == 1){player[hitNo] = player[hitNo] + 8;}
  if(received[6] == 1){player[hitNo] = player[hitNo] + 4;}
  if(received[7] == 1){player[hitNo] = player[hitNo] + 2;}
  if(received[8] == 1){player[hitNo] = player[hitNo] + 1;}
  if(received[9] == 1){weapon[hitNo] = weapon[hitNo] + 4;}
  if(received[10] == 1){weapon[hitNo] = weapon[hitNo] + 2;}
  if(received[11] == 1){weapon[hitNo] = weapon[hitNo] + 1;}
  if(received[12] == 1){hp[hitNo] = hp[hitNo] + 16;}
  if(received[13] == 1){hp[hitNo] = hp[hitNo] + 8;}
  if(received[14] == 1){hp[hitNo] = hp[hitNo] + 4;}
  if(received[15] == 1){hp[hitNo] = hp[hitNo] + 2;}
  if(received[16] == 1){hp[hitNo] = hp[hitNo] + 1;}
  parity[hitNo] = received[17];
  Serial.print("Hit No: ");
  Serial.print(hitNo);
  Serial.print("  Player: ");
  Serial.print(player[hitNo]);
  Serial.print("  Team: ");
  Serial.print(team[hitNo]);
  Serial.print("  Weapon: ");
  Serial.print(weapon[hitNo]);
  Serial.print("  HP: ");
  Serial.print(hp[hitNo]);
  Serial.print("  Parity: ");
  Serial.println(parity[hitNo]);
  //This is probably where more code should be added to expand the game capabilities at the moment the code just checks that the received data was not a system message and deducts a life if it wasn't.
  if (player[hitNo] != 0){hit();}
  hitNo++ ;
void shoot() {
  if(FIRE == 1){ // Has the trigger been pressed?
    Serial.println("FIRE 1");
    sendPulse(IRtransmitPin, 4); // Transmit Header pulse, send pulse subroutine deals with the details
    delayMicroseconds(IRpulse);
    for(int i = 0; i < 8; i++) { // Transmit Byte1
      if(byte1[i] == 1){
        sendPulse(IRtransmitPin, 1);
        //Serial.print("1 ");
      //else{Serial.print("0 ");}
    for(int i = 0; i < 8; i++) { // Transmit Byte2
      if(byte2[i] == 1){
       // Serial.print("1 ");
    if(myParity == 1){ // Parity
    Serial.println("");
    Serial.println("DONE 1");
  if(FIRE == 2){ // Where a secondary fire mode would be added
    Serial.println("FIRE 2");
    sendPulse(IRtransmitPin, 4); // Header
    Serial.println("DONE 2");
FIRE = 0;
ammo = ammo - 1;
void sendPulse(int pin, int length){ // importing variables like this allows for secondary fire modes etc.
// This void genertates the carrier frequency for the information to be transmitted
  int i = 0;
  int o = 0;
  while( i < length ){
    i++;
    while( o < IRpulses ){
      o++;
      digitalWrite(pin, HIGH);
      delayMicroseconds(IRt);
      digitalWrite(pin, LOW);
void triggers() { // Checks to see if the triggers have been presses
  LTR = TR;       // Records previous state. Primary fire
  LT2R = T2R;     // Records previous state. Secondary fire
  TR = digitalRead(triggerPin);      // Looks up current trigger button state
  T2R = digitalRead(trigger2Pin);    // Looks up current trigger button state
  // Code looks for changes in trigger state to give it a semi automatic shooting behaviour
  if(TR != LTR && TR == LOW){
    FIRE = 1;
  if(T2R != LT2R && T2R == LOW){
    FIRE = 2;
  if(TR == LOW && automatic == 1){
    FIRE = 1;
  if(T2R == LOW && automatic2 == 1){
    FIRE = 2;
  if(FIRE == 1 || FIRE == 2){
    if(ammo < 1){FIRE = 0; noAmmo();}
    if(life < 1){FIRE = 0; dead();}
    // Fire rate code to be added here
void configureGame() { // Where the game characteristics are stored, allows several game types to be recorded and you only have to change one variable (myGameID) to pick the game.
  if(myGameID == 0){
    myWeaponID = 1;
    maxAmmo = 30;
    ammo = 30;
    maxLife = 3;
    life = 3;
    myWeaponHP = 1;
  if(myGameID == 1){
    myWeaponID = 1;
    maxAmmo = 100;
    ammo = 100;
    maxLife = 10;
    life = 10;
    myWeaponHP = 2;
void frequencyCalculations() { // Works out all the timings needed to give the correct carrier frequency for the IR signal
  IRt = (int) (500/IRfrequency);
  IRpulses = (int) (IRpulse / (2*IRt));
  IRt = IRt - 4;
  // Why -4 I hear you cry. It allows for the time taken for commands to be executed.
  // More info: http://j44industries.blogspot.com/2009/09/arduino-frequency-generation.html#more
  Serial.print("Oscilation time period /2: ");
  Serial.println(IRt);
  Serial.print("Pulses: ");
  Serial.println(IRpulses);
  timeOut = IRpulse + 50; // Adding 50 to the expected pulse time gives a little margin for error on the pulse read time out value
void tagCode() { // Works out what the players tagger code (the code that is transmitted when they shoot) is
  byte1[0] = myTeamID >> 2 & B1;
  byte1[1] = myTeamID >> 1 & B1;
  byte1[2] = myTeamID >> 0 & B1;
  byte1[3] = myPlayerID >> 4 & B1;
  byte1[4] = myPlayerID >> 3 & B1;
  byte1[5] = myPlayerID >> 2 & B1;
  byte1[6] = myPlayerID >> 1 & B1;
  byte1[7] = myPlayerID >> 0 & B1;
  byte2[0] = myWeaponID >> 2 & B1;
  byte2[1] = myWeaponID >> 1 & B1;
  byte2[2] = myWeaponID >> 0 & B1;
  byte2[3] = myWeaponHP >> 4 & B1;
  byte2[4] = myWeaponHP >> 3 & B1;
  byte2[5] = myWeaponHP >> 2 & B1;
  byte2[6] = myWeaponHP >> 1 & B1;
  byte2[7] = myWeaponHP >> 0 & B1;
  myParity = 0;
  for (int i=0; i<8; i++) {
   if(byte1[i] == 1){myParity = myParity + 1;}
   if(byte2[i] == 1){myParity = myParity + 1;}
   myParity = myParity >> 0 & B1;
  // Next few lines print the full tagger code.
  Serial.print("Byte1: ");
  Serial.print(byte1[0]);
  Serial.print(byte1[1]);
  Serial.print(byte1[2]);
  Serial.print(byte1[3]);
  Serial.print(byte1[4]);
  Serial.print(byte1[5]);
  Serial.print(byte1[6]);
  Serial.print(byte1[7]);
  Serial.println();
  Serial.print("Byte2: ");
  Serial.print(byte2[0]);
  Serial.print(byte2[1]);
  Serial.print(byte2[2]);
  Serial.print(byte2[3]);
  Serial.print(byte2[4]);
  Serial.print(byte2[5]);
  Serial.print(byte2[6]);
  Serial.print(byte2[7]);
  Serial.println();
  Serial.print("Parity: ");
  Serial.print(myParity);
  Serial.println();
void playTone(int tone, int duration) { // A sub routine for playing tones like the standard arduino melody example
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
void dead() { // void determines what the tagger does when it is out of lives
  // Makes a few noises and flashes some lights
    playTone((1000+9*i), 2);
  Serial.println("DEAD");
  for (int i=0; i<10; i++) {
   analogWrite(ammoPin, 255);
   delay (500);
   analogWrite(ammoPin, 0);
   delay (500);
void noAmmo() { // Make some noise and flash some lights when out of ammo
  playTone(500, 100);
  playTone(1000, 100);
void hit() { // Make some noise and flash some lights when you get shot
  life = life - hp[hitNo];
  Serial.print("Life: ");
  Serial.println(life);
  playTone(500, 500);
  if(life <= 0){dead();}
  lifeDisplay();
3 comments
Nov 16, 2011. 8:46 PMKeanan says:
Okay, I am I have copied your code to my Arduinos and have a similar setup as yours, the only main difference being I am using 56kHz receivers and have changed the IRfrequency variable to 56, but when ever I shoot the other arduino, it just reads ERROR
sensor: 1... 2 2 2 2 0 2 2 0 2 2 0 2 2 2 2 2 2
after the sometimes there is all 2s and sometimes zeros randomly in the string. I also set it up to display received[17] specifically and it is always 2. Why is this?
I also have the Arduinos close to each other, could the short distance be affecting the IR signal?
Any advise would be greatly appreciated.
Dec 5, 2011. 9:38 AMyeshi88 says:
Try removing timeOut paramter in the following line of the code:
If it still does not work , try adding
Serial.println(received[i]); before the following lines.
Your output should fall between 400 - 800 for byte 0 and 1000 - 1400 for byte 1
Nov 26, 2011. 9:55 AMtag says:
Hi,
My lasertag used to work and as of today I am getting the above error as well ?
I have tried J44's suggestions and still nothing? Weird !
Any other suggestions ?
Thanks
Tag
Nov 27, 2011. 8:35 AMtag says:
just had a thought - can this be related to the new Arduino client ?
Thanks
Tag
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:j44(J44 Industries)
