Duncan Phyfe Table Restoration
Introduction: Duncan Phyfe Table Restoration
Restoring a nice piece of furniture which had been ruined with paint.
Step 1: Duncan Phyfe End Table Removing the Old Paint
Removing the old paint,I learned a tip from an older refinisher . I sprayed the table with oven cleaner. Once it is sprayed you leave it on working for about ten minutes I used a plastic straight edge scrapper. I then rinsed it off with water.
Step 2: Respraying Oven Cleaner
Sometime the old finish or paint has to be removed in stages.It has to be sprayed two or three times to remove all.Once you are finished spaying and scrapping rinse it off for the final time.Depending how much rinsing you need.I then put it in front of a fan to fully dry it off.Can you imagine the amount of sanding especially in the small cravaces.
Step 3: Finishing the Stain and Poly
Once the paint and old poly has been taken off it can be restrained and refinished with poly.
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
Thanks for the tip of the oven cleaner, it's a neat idea :)
your welcome it has saved me hours of sanding.
All that work why not restore the old shellac finish
I used what the lady who it belonged to,had furnished
The oven cleaner removed all the old finish. I wrote poly in the detail contents,but it was actually varnish I do this kind of work for a part time pass time.The lady who owned the table brought me the stain and finish she wanted.
