Durable Hardwood Bench
4,277
182
Posted
Introduction: Durable Hardwood Bench
This is a very simple tutorial. I made this bench about 3 months ago. It's a simple design for a bench that will last a long time.
Step 1: Materials
- 2 concrete blocks
- hardwood 2"x3" (45mmx70mm)
- Inox screws
- Threaded wire (M8)
- Heatshrink
Step 2: Make It!
Step 1: Mill the wood. I bought hardwood pieces of 3 meter. The bench is 1,5 meter in length so I cut the wood precisely in half. Also mill the two shorter pieces.
Step 2: Place the threaded wire. Drill a 7,5mm hole in the shorter pieces of wood, to fit in a piece of M8 threaded wire. It should be very sturdy, but to be sure you can lock it with some glue.
Step 3: Heat shrink the threaded wire (optional). I put a heat shrink around the pieces of threaded wire just to protect it form damaging the concrete blocks.
Step 4: Screw everything together. You're now ready to screw everything together. Be sure to pre-drill every hole. It's easy to snap off one of your screws when you don't pre-drill correctly.
Step 5: Make holes in the concrete blocks: Drill holes in the concrete blocks that fit your pieces of threaded wire.
You're Done!
Step 3: Planters
Another option is to make this bench with planters on both sides.
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Comments
    Nice! Reminds me of George Nelson's Slat Bench....(he was the design director that hired Charles Eames for Herman Miller originally...)
    very well looking
    and awesomeeeeeeeeeeee gonna do the same
