3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dust Sniper (quiet extractor system)
Step 15In Use, Evaluation, Maintenance
Lets evaluate the DS in relation to the design goals which were:
1) Effective removal of dust from hand-held tools and bandsaw
2) Little or no noise
3) Provide strong but wheelable work surface
1) The removal of dust thus far is excellent. The dust is sucked up and separated by the cyclones into the collection barrels. Because the separation efficiency is so good suction remains very high - no regular cleaning filters or changing of bags required. Obviously the collection barrels need emptying occasionally, but being many times bigger than a bag or standard shopvac canister, this is an easy and infrequent chore. Thus far, I have only had to change a vacuum bag after I got carried away and let the barrel become full, which resulted in the dust quickly clogging up the vacuum bag and suction becoming very weak.
So yeah, it might be worth me trying to make some kind of warning sensor that tells me when the collection barrels are approaching fullness to avoid similar problems in future. I already put a viewing window into one of the collection barrels, problem is that the static causes it to be obscured with dust, so that's little to no help. Some of you have already made some good suggestions on how to overcome this little problem in the comments. Of course any other ideas are very welcome...
2) Noise wise I am better pleased that I expected to be. When the DS is all closed, shut up and operational, I can't really hear the noise of the vacuums at all! The noise of the air rushing through the hose is pretty much all that is audible. So jackpot on the sound front. I can't tell you how nice it is to be able to clear up the shop and suck up dust without a loud noise. It makes nice quiet, well balanced power tools more worthwhile ;)
Now bearing in mind  there are many differing and complicated techniques of sound measurement, the audiophiles may want to look away now. In a blissfully and probably horrifyingly simplistic manner, I used a mobile phone with an in-built 'sound meter' to do my measuring.
Sound of both vacs out in the open - 85dB
Sound of one vacuum in the open - 83dB
Sound of both in the DS - 61 (but varies a lot depending on where the end of the hose is situated - the air rushing in at the tip is almost the only precipitable noise)
Sound of one in the DS - 55
3)  The work surface is nice, functional, and sturdy enough to dance on. I do need to add a breaking mechanism to the wheels, so that I can lock it in place better.
Parting Thoughts
The DS has been a long project for me, with plenty of help, research and tweaks needed along the way. Still, it has come together in the end and with any luck this instructable will help you guys avoid some the mistakes I made. Already a number of you have said you will be making your own DS, so I look forward to feedback, build photos, and areas of development. If it improves the working environment (and health!) of one of you, my fellow makers, hackers and craftspeople, then great!
3 comments
Feb 5, 2011. 4:52 PMwiml says:
Thinking laterally about bucket sensors: perhaps you could put a small tube into the collection bucket near the top, connected to some not-very-strong source of vacuum. When the bucket fills, the sawdust blocks the tube, making the pressure in the tube drop, which then ... um ... raises a flag, or triggers an electronic pressure sensor, or the like.
Or, alternately: isn't the interior of the bucket at below-atmospheric pressure? The tube could be connected to 'outside' air though a small hole. When the bucket is not yet full, airflow into the bucket keeps the tube below atmospheric. When the bucket fills past the tube, airflow stops. Let's see if I can attach a sketch of this idea... I can't decide if it'd be horribly finicky and impossible to implement, or if it would be perfect and elegant. :)
Electronic pressure sensors are around $15 new but maybe there's a good junk source for them...
Jan 6, 2011. 9:04 AMjeff-o says:
I wonder if you could put a small digital scale with a remote readout under the barrels. When the barrel hits a certain weight, you know it's time to empty it.
Any kind of optical sensor inside the barrel would be obscured just like the window, and other sensors are out because of the static. But yeah - weight would probably work.
Feb 4, 2011. 12:33 PMDeadlyDad says:
How about using a simple, light flap and a cherry switch, along the inside of the barrel at the 'full' line. Have a spring on it so that it normally sticks out when the system is off. When the system is in operation, the flap will be forced against the side. If the flap doesn't swing back out when the system is turned off, something is blocking it, and the barrel can be assumed to be in need of emptying.
Jan 6, 2011. 10:49 AMjeff-o says:
Ah, true. I forgot that the barrels were connected to the cyclones. Perhaps with a short flexible tube (flexible ducting?) between the two it would work.
Jan 12, 2011. 10:28 AMjeff-o says:
I was thinking of that. And yeah, if you're sucking up plastic and metal along with the wood then it could be a problem. But really, they shouldn't be mixed in the first place (sawdust can be used for other things!) And as for different density woods, unless you're doing a lot of work with ebony and cocobolo, I doubt it'll present much of a problem. In most cases, people will be using oak, pine, maple, and poplar. Set your threshold for a bucket full of oak sawdust and you'll be good to go!
Jan 12, 2011. 1:39 PMjeff-o says:
It's true, the barrels don't have to be full. So, you'd make a "best guess" estimate of what weight the barrel should be when it needs to be emptied. Then over the course of a few "empties" you could adjust the threshold up or down accordingly. I think you'd find the weight would, on average, be about the same assuming you use the same types of woods and processes on a regular basis.
Jan 12, 2011. 11:07 AMPazzerz says:
I guess with all the problems with densities, the best thing would be to do what we do every time we vacuum the house: Visually check the container and empty it prior to use. A bit old fashioned, but it works.
Jan 10, 2011. 12:15 PMdcorbett says:
WAY AWESOME!!! I loved the reed switch auto on/off idea. Plain to see you put some extra effort into this one.
Try ultrasonic for measuring the level in your bucket.
The transducer can be mounted at the top (to provide "analog" measurement), or on the side (use as ON/OFF or "dump alert").
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:bongodrummer(Flowering Elbow Website)
BongoDrummer is founder and member of Flowering Elbow. He loves to learn about, invent, and make things, particularly from waste materials.
