3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dust-catching Glove Box
I'm in the middle of a project where I need to do a lot of working with plastic. Which when cut or sanded produces Large Amounts of fine, choking sawdust. I got a couple of nosefuls (and the Dremel throws it RIGHT in your face) and decided that Something Had To Be Done.
(When I was a kid, my best friend's father had a shop in his basement, and one time I went down there and he was sandblasting something. He had rigged up a fishtank with holes in the sides and rubber gloves stuck in them to hold the item being worked. I have no recollection of what he was making, but I remember the tank. I always kind of wanted one...)
Materials:
  • one plastic box with attached lid, available at houseware stores
  • one pair long rubber gloves
  • some duct tape
Step 1Arm holes
Arm holes
Open the lid and pretend to work on something in the box, to get a sense of where your arms want to be. Draw a rough guide with a sharpie. With a cutting wheel, or a hot knife, or whatever you like to use to cut plastic, cut out the holes. Tidy the edges up some so they don't scrape you.
The box is now usable; dust won't fly directly into your face now. But it will still come out of the armholes, and your hands will still be all covered in it. An improvement can be made!
11 comments
May 18, 2008. 7:51 PMremusblack says:
nice job! Why not add a vacuum attachment thus making your glove box virtually dust free ? =D
Jul 8, 2011. 2:28 AMMimikry says:
very nice instructable - i'll make one for sure!
the idea to attach the vacuum cleaner is a great update!
May 3, 2008. 5:05 PMRaisedByRobots says:
This is a really nice idea. Maybe you could put a window of clear acrylic on top so you could see a little better, the clear plastic box looks a bit cloudy. Nice solution to a common problem.
Mar 17, 2009. 4:26 PMmatbh says:
maybe u can use a top cover of transparent glass...
May 2, 2008. 7:18 AMwilcbr01 says:
Very nice! Remarkably simple, yet so effective. Wish I'd thought of this one earlier; would have saved me a lot of messes. Thanks for posting.
May 1, 2008. 4:13 PMrimar2000 says:
Good idea.
May 1, 2008. 7:52 AMmefromliny says:
Excellent write-up! I copied it and added a small shopvac and it works great! Ken
May 1, 2008. 3:26 AMfriezer says:
I've been knocking around the idea of carving emu egg shells, but my first attempt brought to light how utterly disgusting the resultant dust smells. Your project, modified with a dust extracting shop vac just might be the solution to my problem. Thanks for sharing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
242
Author:rachel
I'm a founding member of Noisebridge (https://noisebridge.net), a hackerspace in San Francisco, and Ace Monster Toys (http://acemonstertoys.org/), in Oakland. If you're in the area, stop by and say h...
more »
