Dye Mixer Plc Program/simulation
1,479
8
Posted in TechnologyElectronics
Introduction: Dye Mixer Plc Program/simulation
About: bachelors degree in Electrical Engineering, love developing hardware systems on both microcontrollers and PLC.
Programmable Logic Controllers,are for industrial use mostly.They are robost and expensive because the can be installed in areas with harsh weather conditions and are expected to last for longer periods of time.
Here we look at the use of a PLC in an industrial dye mixer.
Problem description
The problem is to implement an automation of a dye mixing machine.
Dye mixer operation starts by the press of a Start push-button and stops at anytime by Stop push-button press.During the operation green indicator Lamp should light permanently.
The dye from the three basic dye (Green, Red, Blue) tanks goes to the mixing tank through magnetic valves. PLC controls opening / closing of all magnetic valves. The machine has to mix a given color. The red dye is filling to mix tank for 2 s, the green one for 3 s, and the blue one for 4 s. Filling of the dye starts simultaneously with 2 s delay after the press of start push button.
If all necessary dyes are in the mixing tank, then after 3 s the mixing motor starts and mixes dye for 8 s. The motor is a 3-phase asynchronous motor that needs star-delta start up. Start-delta switching time is 3 s.
After mixing the drain magnetic valve is necessary to open immediately. If the tank becomes empty, the magnetic valve i needed to close and the mixing process has finished. The level-switch indicates if the tank is empty.
The dye mixing can be restarted by Start Push button repress.
The first to solving any electrical problem is to know the Number of I/O devices,function block and as well as their address.The program is attached and you can download and walk through and study it,you can run the simulation as well while looking at the description. This program was written using an easysoft coDesys or easy800
Both the easysoft and easy800 programs are attached here.I hope this can help people familiar with this programing environment.
For people who are not, the problem description is really catchy and can also be solved using arduino or raspberry or any other kind of microcontroller. Enjoy.
  • Microcontroller Contest
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
2 Comments
Hello there, I apologize for the trouble and the timing, but I am curious to know what means did you use to program this project? Iseasysoft coDesys a program that works in hand with the programmer easy800? or is it just a simulator. I was working with this code to be able to pull this project together for my final PLC but it is not working so I wondered if you program it with any type of arduino or raspberry. and lastly could you be so kind to send me any material you might have about this project please (julie.gomez001@mymdc.net)?
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
int keys[] ={ //Stores total keypad input
1, 2, 3, 10, 4, 5, 6, 11, 7, 8, 9, 12, -3,0, -2, 14}; //"123A456B789C*0#D";
int key; //Stores most recent key pressed
boolean key_lockout=false;
int order[4];
int value=0;
//Initialize
const int vodka=3; //Based on 6v clear pump, 13.3 sec/oz (20 sec/1.5 oz)
const int gin=4; //Based on 12v black pumps, 25.3 sec/oz (38 sec/1.5 oz)
const int whiskey=5;
const int tripleSec=6;
const int tequila=7;
const int rum=8;
const int water=9;
const int simpleSyrup=10;
void setup(){
Serial.begin(9600);
lcd.begin(16,2);
pinMode(vodka, OUTPUT);
pinMode(gin, OUTPUT);
pinMode(whiskey, OUTPUT);
pinMode(tripleSec, OUTPUT);
pinMode(tequila, OUTPUT);
pinMode(rum, OUTPUT);
pinMode(simpleSyrup, OUTPUT);
pinMode(water, OUTPUT);
digitalWrite(vodka, HIGH);
digitalWrite(gin, HIGH);
digitalWrite(whiskey, HIGH);
digitalWrite(tripleSec, HIGH);
digitalWrite(tequila, HIGH);
digitalWrite(rum, HIGH);
digitalWrite(simpleSyrup, HIGH);
digitalWrite(water, HIGH);
// ------- 3 blinks of backlight -------------
for(int i = 0; i< 3; i++)
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); // finish with backlight on
void loop(){
Beginning:
//-------- Write characters on the display ------------------
// NOTE: Cursor Position: (CHAR, LINE) start at 0
lcd.clear();
lcd.setCursor(0,0); //Start at character 4 on line 0
lcd.print("Enter your order");
delay(500);
lcd.setCursor(0,1);
lcd.print(" *-Clr, #-Enter");
delay(1000);
value=0;
for (int x=0; x<4; x++){
key=getKeypad(); //Get key pressed
if(key==-1){ //If valid key not pressed restart iteration
x=x-1;
else{
if(key!=14 && key!=12){ //If not CLEAR or ENTER
value = (10*(value)) + (keys[key]);
delay(10);
lcd.clear();
lcd.print("Item #");
delay(10);
lcd.setCursor(6,0);
lcd.print(value);
delay(500);
else if(key==14){ //If ENTER, exit
x=4;
else if (key==12){ //If CLEAR, restart
x=-1;
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Press # to");
delay(10);
lcd.setCursor(0,1);
lcd.print("Confirm drink");
delay(10);
lcd.setCursor(14,1);
lcd.print(value);
do{
key=getKeypad();
while(key!=12 && key!=14);
if(key==12){ //Restart ordering process
goto Beginning; //Return to the beginning of loop()
else if(key==14){
lcd.clear();
lcd.print(" Confirmed");
delay(1000);
switch (value) {
case 1:
longIslandIcedTea();
break;
case 2:
jackAndCoke();
break;
case 3:
rumAndCoke();
break;
case 4:
capeCod();
break;
case 5:
cosmopolitan();
break;
case 6:
kamikazee();
break;
case 7:
screwdriver;
break;
case 8:
highball();
break;
case 9:
gt();
break;
case 10:
vodkaTonic();
break;
case 11:
margarita();
break;
case 12:
seaBreeze();
break;
delay(5); // delay in between reads for stability
//--------Functions-----------
int getKeypad(){ //Returns which key is pressed
int ret=-1;
boolean reset_lockout=false;
if(analogRead(A0)<120)
key_lockout=false;
else if(!key_lockout){
delay(100);
ret=15.5-(log((analogRead(A0)-183.9)/58.24)/0.1623);//+0.5;
key_lockout=true;
return ret;
// Menu
//Long Island Iced Tea
int longIslandIcedTea(){
digitalWrite(vodka, LOW);
delay(80);
digitalWrite(gin, LOW);
delay(80);
digitalWrite(tripleSec, LOW);
delay(80);
//Serial.println("In the matrix");
digitalWrite(tequila, LOW);
delay(80);
digitalWrite(rum, LOW);
delay(80);
digitalWrite(water, LOW);
delay(6600);
delay(6400);
for (int x=0; x<3; x++){
lcd.clear();
lcd.print("Add 1oz Sour Mix");
delay(10);
lcd.setCursor(0,1);
lcd.print(" then MIX");
delay(5000);
lcd.clear();
lcd.print("Add ice and ");
delay(10);
lcd.setCursor(0,1);
lcd.print("top with coke");
delay(3000);
//Jack and Coke
int jackAndCoke(){
//2 oz of whiskey
Serial.println("Jack and Coke");
digitalWrite(whiskey, LOW);
delay(10);
delay(4500);
delay(33500);
lcd.clear();
lcd.print("Add ice and 2-5");
delay(10);
lcd.setCursor(0,1);
lcd.print("ounces of Coke");
delay(8000);
//Rum and Coke
int rumAndCoke(){
//2 oz of rum
Serial.println("Rum and Coke");
delay(10);
delay(4500);
delay(33500);
lcd.clear();
delay(10);
lcd.setCursor(0,1);
delay(8000);
//Cape Cod
int capeCod(){
//2 oz of vodka, 3 oz cranberry juice, lime wedge
Serial.println("Cape Cod");
delay(10);
delay(4500);
delay(15500);
lcd.clear();
lcd.print("Add ice & 2-3 oz");
delay(10);
lcd.setCursor(0,1);
lcd.print("Cranberry Juice-");
delay(3000);
lcd.clear();
lcd.print("and a lime wedge");
delay(3000);
//Bay Breeze
int bayBreeze(){
//2 oz of vodka, 5 oz cranberry juice, 2 oz pineapple juice (or equal parts ~2.5 oz each), lime wedge
Serial.println("Bay Breeze");
delay(10);
delay(4500);
delay(15500);
lcd.clear();
lcd.print("Add ice & 4-5 oz");
delay(10);
lcd.setCursor(0,1);
lcd.print("Cranberry Juice");
delay(4000);
lcd.clear();
lcd.print("and 2oz of");
lcd.setCursor(0,1);
lcd.print("Pineapple Juice");
delay(3000);
//Cosmopolitan
int cosmopolitan(){
//1 1/2 ounces vodka or citrus vodka, 1 ounce Cointreau orange liqueur, 1/2 ounce fresh lime juice, 1/4 ounce cranberry juice
Serial.println("Cosmopolitan");
delay(10);
delay(10);
delay(13000);
delay(7000);
delay(5323);
lcd.clear();
lcd.print("Add 1/2 oz lime");
delay(10);
lcd.setCursor(0,1);
lcd.print(" Juice and MIX");
delay(4000);
lcd.clear();
lcd.print(" Top with");
lcd.setCursor(0,1);
delay(3000);
//Kamikazee
int kamikazee(){
//1 1/2 -1 ounces vodka, 1 ounce lime juice, 1 ounce triple sec, Lime wedge for garnish
//shake
Serial.println("Kamikazee");
delay(10);
delay(10);
delay(13000);
delay(7000);
delay(5323);
lcd.clear();
lcd.print("Add 1 oz Lime");
delay(10);
lcd.setCursor(0,1);
delay(4000);
lcd.clear();
lcd.print(" Add Ice");
lcd.setCursor(0,1);
lcd.print("and lime wedge");
delay(3000);
//Screwdriver
int screwdriver(){
//1 1/2 -1 ounces vodka, 5 oz orange juice
Serial.println("Screwdriver");
delay(20000);
for (int x=0; x<2; x++){
lcd.clear();
lcd.print("Add Ice and ~5");
delay(10);
lcd.setCursor(0,1);
lcd.print("oz Orange Juice");
delay(3000);
//Highball
int highball(){
//1.5 ounces whiskey, ginger ale
Serial.println("Highball");
delay(38000);
lcd.clear();
lcd.print(" Add Ice and");
delay(10);
lcd.setCursor(0,1);
lcd.print(" Ginger Ale");
delay(8000);
//Gin and Tonic
int gt(){
//1.5 ounces gin, 2.25 tonic or 2:3, 1/4 oz lime juice
Serial.println("Gin and Tonic");
delay(38000);
lcd.clear();
lcd.print("Add Ice, 2-5 oz");
delay(10);
lcd.setCursor(0,1);
lcd.print("of Tonic and...");
delay(3000);
lcd.clear();
lcd.print(" 1/4 oz");
lcd.setCursor(0,1);
lcd.print(" Lime Juice");
delay(3000);
//Vodka Tonic
int vodkaTonic(){
//1.5 ounces vodka, 3-4.5 tonic, 1/4 oz lime juice
Serial.println("Vodka Tonic");
delay(20000);
lcd.clear();
delay(10);
lcd.setCursor(0,1);
delay(3000);
lcd.clear();
lcd.setCursor(0,1);
delay(3000);
//Margarita
int margarita(){
delay(10);
delay(10);
delay(13000);
delay(12700);
delay(12870);
lcd.clear();
lcd.print("Add 1/2 oz of");
delay(10);
lcd.setCursor(0,1);
lcd.print("Lime Juice &...");
delay(3000);
lcd.clear();
lcd.print(" MIX");
lcd.setCursor(0,1);
lcd.print(" then add ice ");
delay(4000);
//Sea Breeze
int seaBreeze(){
//1.35 Vodka, 4 Cranberry juice, 1 Grapefruit juice
Serial.println("Sea Breeze");
delay(18000);
Hi
I need to do this PLC mixer with arduino for a presentation, any help please
