loading
I ombré dyed our duvet cover ages ago, and then I had about ten ladies over for an ombré dyeing party, yet I'm somehow only just now managing to scrape together a tutorial! I'll be sure to show you the duvet cover sometime soon, along with tips and tricks for dyeing such a large piece. In the meantime, you should try this. A couple of my  ombré crafternoon party attendees dyed swimsuit coverups, and they turned out just as summery as can be. I definitely recommend a nice, bright lemon yellow for summer, and it fades light to dark really well!
If you have questions after you read through everything, leave 'em in the comments on this post, and I'll reply as soon as I can. There's a little bit of a learning curve to get a really nice, gradual fade, but it's fun to learn!
Step 1: What You Need
Click here for links to where I purchase my dye and soda ash.
  • White or light-colored natural-fiber garment (cotton, rayon, hemp, silk, etc.)
  • Fiber reactive dye (Dharma Trading has an insane range of colors!)
  • Soda ash
  • Table salt
  • Disposable gloves
  • Marker
  • Ruler or tape measure (bonus if it's shaped like an owl)
Step 2: Flip & Dot
Flip your garment (shirt) inside out. Decide how far up you want the color to go. This will be the lightest part of the ombré. Mark a small dot there on the seam with your marker. Now, mark dots all the way down at even intervals, all the way to the bottom of the shirt. I marked a dot every two centimeters. Each dot will later guide how much of the shirt will get the next amount of dye. Since you're marking on the inside seam, nobody will ever see the dots.
Step 3: Mix & Dunk
Wash your garment ahead of time to get any residue off it. Mix water hot from the tap with the salt and soda ash. You'll add one cup of salt and one tablespoon of soda ash per gallon of water. Stir it until it's mixed thoroughly. Dunk the shirt, and then wring it out thoroughly.
Step 4: Dye Slurry
Put on your gloves! Dump about two tablespoons of powdered dye into a bowl, and add a little water. Mix to form a paste, and then add some more warm water, mixing carefully until you have no more clumps of powder. This dye is incredibly concentrated and will stain everything, so be very careful! (I used Dharma's PR22 Cobalt dye color.)
Visit the tutorial on my blog for reasons why I prefer this dye over the store-bought stuff.
Step 5: Tint the Water
Add dye to the water 1/4 teaspoonfull at a time, until you have a light color. You can test it by dipping a white rag or paper towel. You want the color to barely show up. Stir it really well. Now put a rod of some sort - even just a clothes hanger - over the top of the bucket to hang the shirt.
Step 6: Dip & Drape
Drape the shirt over the rod, and drop the bottom into the water until the top dot is level with the top of the water. Let it soak for three to five minutes.
Step 7: Retract & Darken
Make sure you have no dye on your gloves. Pull the shirt up, letting the excess hang over the side, until the second dot is level with the top of the water. Now, very carefully, add another 1/4 teaspoon of dye. Dip it into the side of the bucket away from the shirt, and swirl the teaspoon in the water until the dye has all soaked into the water. Now stir it around with your big spoon, and let that layer soak another three to five minutes.
Step 8: Less Dip & More Dye
Continue pulling the shirt up, one dot at a time, while you add one more spoonful of dye at each new layer. To deepen the effect, you can let the layers soak a bit longer each time so that the darker layers absorb more dye. When you get to the bottom, grab the shirt by the top, and wring it out from the top down into the bucket. Now throw it in the washer by itself, and wash it on the cold cycle. Voila - you should have a new piece of clothing with a gorgeous gradient!
I have a few more tips on step seven of the tutorial in this blog post
<p>super helpful tutorial! I've always wondered about how to get an ombre effect without just ending up with progressively darker stripes, as seems quite common. yours came out really nicely. i'm totally going to try this this weekend!</p>
I've been wondering how to do this since I saw a dip-dye thermal on jacksthreads that I haven't been able to find anywhere else. <br> <br> <br>I don't think Dip and Ombre dying are the same thing but I think they're fundamentally similar.
Wouldn't it be easier if you do it backwards? As in: add to the water the amount of dye that you would normally use to finish your shirt, and then dunk the bottom in, let it soak for a while, and then keep moving up the shirt. The longer exposure would make the bottom darker than the rest, which would get less time in the water.
FACEfun - I've actually tried it both ways, and I find the way I explained in this post much easier to control. I had friends over, and we tried the other way. It looked great on a couple items but was a lot more hit or miss. <br /> <br />It's definitely a possibility. I've just had much better luck doing it the way I describe in the Instructable. Good point, though!
Nice ible! Thanks for sharing, I have so many on my list! <br />sunshiine
So glad you like it, sunshiine! I've done our duvet cover the same way, and I think I might try some napkins soon, too. You can never have too many projects on the back burner, right? lol
Looks like you house is boarded up ! Sorry!
Thanks, but fortunately it's just an abandoned house nearby. Mine's doing just fine. :D
D'Arcy loves hers....I am waiting for another soccer/crafts get-together so I can make mine! <br />
How about ombr&Atilde;&copy; jerseys? Which team can I talk into that so that we can design all their goods?! And thanks for the support, sir!
great shirt. interesting choice for background with the boarded up house
Thanks, L! There are unfortunately several boarded up houses around, but it makes for a unique locale for a photo, anyway.
This is great, thanks for the share.
You're welcome, Audrey. I'd love to see pictures if you try it out!
About This Instructable
64,274views
181favorites
Bio: I'm a bit of a crazy cat lady with a penchant for red wine, travel, and making something from nothing. I blog at Shrimp ... More »
More by ShrimpSaladCircus:Backyard Grilled Pizza Tiny Travel Honey Soap Gems Homebrewing 101 + Free Printable Labels
Add instructable to:
