Dyeing a Baseball Glove
Introduction: Dyeing a Baseball Glove
This is not my work. All work was done by Dan Davis of Davis Relacing. I am just compiling pictures from a Facebook post that Dan made and organizing it so it will be easier to understand. Hope I do it some justice.
Step 1: Disassemble Glove
Remove all lace, tags and padding(if possible)
Step 2: Take Pictures
You want to have something to compare your finish product with!
Step 3: Clean
Clean with a good cleaner and sponge. You must get all traces of dirt off the glove! You may need to use a scrubber to gently remove sheen and tar buildup. Then let it dry! This is a must. It must be completely dry before the next step.
Step 4: Wipe It Down
Wipe glove down 2-3 times with liberal amounts of rubbing alcohol to remove
any final traces of grease, etc. that could prevent proper dye penetration. *Use a new, clean sponge for this step. Then let it dry completely again!
Step 5:
Dye glove following manufacturer's directions. I've used Tandy Eco-flo and Fiebings dye with similar results. I use a clean sponge to carefully apply dye over entire surface. Use a fine paintbrush for detail areas such as around stitching or logos.
Step 6: Hang & Dry
Hang glove to dry overnight. Did you remember to wear gloves?
Step 7: Prep for Sealer
Time to prep for sealing. When the glove has received the appropriate number of coats for your leather coverage or manufacturer's directions, you must remove any excess dye that did not penetrate.
Using a soft rag or lambs wool, buff any excess dye residue from the entire glove. Buff over the glove in one direction, then go over it again in another direction. * if you don't remove the excess, you may experience problems with the sealer and/or dye may rub off
Step 8: Detail
DETAIL: rag after wiping. Notice the excess dye. You must wipe/buff the glove until no more dye is removed on a clean portion of your rag!
Step 9: Apply Sealer
After the glove has dried and all excess dye has been removed, follow manufacturers directions on your sealer.
*I prefer Tandy Eco-Flo Satin Shene for its ease of use, water cleanup, and soft shine to the finished glove.
After it completely dries, buff with a soft cloth to bring an even finish to the glove surface
Step 10: Relace
Relace your glove & enjoy!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Thanks! Dan does great work. Hopefully it will help someone save one of these great old gloves from the scrap heap
    This turned out really nicely! Thank you for sharing this process.
