3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Dynamo powered LED bike lights
Step 3Part list
- 1W power led (luxeon, SSC P4, Cree or something similar) on star PCB - it must withstand at least 500mA current.
(it looks like [http://commons.wikimedia.org/wiki/Image:2007-07-24_High-power_light_emiting_diodes_(Luxeon,_Lumiled).jpg that])
- Collimator or reflector suited for above power LED with 10 - 30 degrees beam width (10 degrees has visible light-spot in longer range; 30 deg. puts more light to the sides and is more visible for others)
- 3 (or 4 when You don't make the tail light) Shottky diodes (for example 1N5818) for rectifying (faster, lower voltage drop). the normal silicone diodes will also do.
- 13 - 15 red diodes for the tail lamp
- a base for tail light (universal PCB is very good)
- Capacitor C1 - 2200uF 4V
- Capacitors C2 and C3 470uF 63V
- Resistor R1 - 47kOhm
- 1 Longer Bolt and 2 nuts for LED mount/heatsink
- Plastic tubing for the casing
- some casing for tail light (I used some clear plastic rail in which integrated circuits are transported)
- some length of 2 wire cable for connecting dynamo, rectifier, head and tail light
3 comments
Jan 2, 2009. 7:37 PMkmossman says:
(removed by author or community request)
Aug 12, 2010. 11:37 AMStuNutt says:
You mean Germanium diodes (they are made in many countries LOL!), but you are right otherwise.
Jan 1, 2009. 6:49 PMkmossman says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:kptBurek
