"Dyno" for locomotives
 by zorwick
Featured
“If you want something done, do it yourself. Yep!” says Mr. Zorg in the Fifth Element. Probably motivates us to start our projects.
I am a big fan of model trains but unfortunately I do not have a permanent room but what can I do if I already have a nice collection of trains especially steam engine models?
It is so nice to see the spinning wheels and moving rods. I was looking for a nice solution to display some of my collection and also run the engines. On the market there are a several products available for high price, with limited ways to place a large American steamer. So here comes again, I have to do something better and nicer myself. :)
The Broadway Limited came out once with a display bridge designed for the expensive brass Big Boy, but there were only fixed bearings and only for the Big Boy wheel arrangement. The basic idea was there I just needed to re-think and modify my display to serve different axis arrangements and have a nice look.
some_text
Lately I found this very interesting photo about a steamer dyno. So they actually existed in a kind of similar way as my design. Nothing new under the sky. :)
I already have plans to build a real loco dyno with measuring feature.
Step 1: The displays
Bridge I., ( I call: the cherry bridge) has a cherry wood base and hand cut hard wood structure. I used ready made 4 x 4 mm and 2 x 2 mm hardwood rods from the local model shop. Cut all the elements and glued them together. The bridge structure is painted to very dark brown color.
Bridge II., (I call: the wenge bridge) has maple and wenge wood base and laser cut wenge structure what I only nailed, except the top of the bridge where the tracks are, there I had to use some glue. The finishing is only tung oil, amplifying the beautiful color and the wood grains of the wenge.
Both bridges are capable to handle the Big Boy as the biggest loco. The wenge bridge has lighting separately switchable on both side of the display. Both can be used under analog or DCC (digital) mode, only need to plug the 2 track wires.
These bridges at this stage can not handle 3-rail system models, such as a Marklin. For that a little tweaking is necessary.
Videos of the bridges:
Let’s see the details...
taban21 says: Jan 13, 2013. 11:13 PM
very cool
excellent
themadcat says: Nov 23, 2012. 11:30 AM
What are locomotives? Are they handmade?
zorwick (author) in reply to themadcatNov 23, 2012. 12:09 PM
No, they are very fine models from MTH and Broadway Limited.
I wish to make this kind of engines :)
erazor983 says: May 23, 2012. 3:59 PM
I've not been into model trains for several decades, but this instructable caught my eye for some reason. I have to say I'm glad I took the time to read it! Excellent photography, very well written, and showcasing some masterful craftsmanship
mathman47 says: May 22, 2012. 11:56 PM
When I first saw this, I said, "Wait, isn't there something out there like this?" If so, it certainly cannot be of this quality or precision. This is a work of art. Craftsmanship is still alive, as well as love of a project.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
