E-waste CNC 3D Print
2,537
28
Posted
Introduction: E-waste CNC 3D Print
Why create a CNC?
costs It is best to buy? I can not give me that luxury !!! (To live in a place with a bad change Argentina $ 17 - 1u $ d is not difficult to buy technology, and if you buy through legal means as much as possible is left in the
customs, there you must pay a fine for importing / den luxury objects / = O =% & $ the putaaa, from when buying a tool is a luxury, well, hopefully
change that !! and also we pay a bribe or bond to the customs
Experience (Which you realize you learn without a doubt)
Good to work and to work on the project !!
bueno ahora en español !!!
Por que crear una CNC ?
Costos No es mejor comprarla ? No me puedo dar ese lujo !!! ( al vivir en un lugar con un mal cambio Argentina $17 - 1u$d es dificil comprar tecnologia , Y si comprarla por vias legales lo mas posible es que quede en la
aduana, hay deberas pagar una multa por importar /objetos den lujo/ =?O=%&$ la putaaa , desde cuando comprar una herramienta es un objeto de lujo , mas una coima o pago ilegal al despachante de turno , bueno , esperemos
que cambie eso !! y ademas deberemos pagar una coima o fianza al aduanero
Experiencia ( lo que realizas lo aprendes sin lugar a dudas)
Bueno manos a la obra y a trabajar en el proyecto !!
Step 1: Materials
materials
Well, what we have is ..
Knowledge, willingness to work, simple tools.
... We need several things ... but not too many ideas on how to perform them
This project was done in our mutual cooperation with my friend ing Zink
We went out every Friday after school to search for e-waste in homes of computer, obtaining 20 printers.
Disarming all we managed to rescue several step by step, and then configure engines.
Problems !!! It is difficult to get similar engines !! if they are not the same in arduino difficult settings.
Materiales
Y bueno , lo que tenemos es ..
Conocimiento , ganas de trabajar , herramientas sencillas .
Nos falta ... varias cosas ... pero no sobran ideas de como realizarlas
este proyecto fue realizado en coperacion con mi amigo ing Zink
Salimos todos los viernes luego de clases a buscar basura electronica en casas de informatica, obteniendo unas 20 impresoras.
Desarmando todo logramos rescatar varios motores paso a paso , para luego configurarlos.
Problemas !!! es complicado conseguir motores similares !! si no son los mismos dificulta la configuracion en arduino.
Step 2: Mini CNC
The 1st version build it with the idea of drawing circuits for saltearnos other cumbersome processes in the production of circuit boards.
Arduinos use and easily accessible components, the electronics trafic of Paraguay (country with free import :))
That happiness, work the contraption !!!
Well now to work on the CNC - 3D on a larger scale.
This is the master guide
https://www.instructables.com/id/eWaste-60-3DPrinte...
La 1er version la construimos con la idea de dibujar circuitos, para saltearnos otros engorrosos procesos en la produccion de circuitos.
Usamos arduinos y componentes de facil acceso, la electronica la tragimos de Paraguay (pais con libre importacion :) )
Que felicidad , funciona el artilugio !!!
Bueno ahora a a trabajar en la CNC - 3D en escala mayor .
Step 3: The CNC
issues
3D print and extruder hot bed ----
warm bed, this was easy to solve, 2 glasses and a copper wire that acts as resistance
Important that the wires are not touching, use as transparent insulation tape sacreficio, this is gradually burning, but holds the glass and copper wire.
Thermostat ! a command and a thermocouple (I cost us enocontrar the correct relationship between the thermocouple and its programming but we did it !!!)
extruder This required us a lot of effort and many tests, we achieved good results by turning copper
Finally we ended up riding a lathe. Polifan milling parts, obtaining good results.
Some one interesant links
https://www.instructables.com/id/Poor-Mans-3D-Print...
https://www.instructables.com/id/MicroSlice-A-tiny-...
The best home made extruder
http://richrap.blogspot.de/2010/10/making-new-extr...
http://blog.reclone3d.com/2012/06/nuevos-cabezales...
http://stylishwebdesigner.com/70-best-websites-to-...
https://3dprint.com/41127/bondtech-extruder-v2/
http://richrap.com/?p=121
https://3dprint.com/17882/lab-paste-extruder/
https://www.youmagine.com/designs/universal-pellet...
To be continued !!!!!! :)
Problemas
3D print---- cama caliente y extrusor
Cama caliente, esta fue facil de solucionar ,2 vidrios y una cable de cobre que actua como resistencia
Importante que no se toquen los cables , use como aislante de sacreficio cinta transparente , esta se quema gradualmente , pero ya el vidrio sujeta el alambre de cobre.
Controlador de temperatura ! un comando y una termocupla ( nos costo enocontrar la correcta relacion entre la termocupla y su programacion pero lo logramos !!! )
Extrusora Esto nos demando bastante esfuerzo y muchas pruebas, torneando cobre logramos buenos resultados
Al fin terminamos montando un torno. Fresando piezas en polifan , obteniendo buenos resultados.
Continuara !!!!!! :)
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    WOW!!!! Amazing
    i also have ALL THE PARTS
    but how to connect the X to the Z axis, where does it come ?
