Introduction: EASIEST LED EVER
This is a very easy to make pocket sized LED that can be made from items you might have laying around your house; if u don't,they are very cheap.
Step 1: Materials
This is all the material that your going to need.
-Listerine pocket pack(empty)
-Small LED light
-Small button-cell battery
-Duck Tape
Step 2: Peel
Peel the sticker off the front.
Step 3: Pop It Apart
If you put your finger in the hole and wedge it up in it on the pack it will pop apart
Step 4: Tape It
Put a piece of tape on the inside of the bottom part of the Listerine pack.
Step 5: Wireing
Touch each wire to each side of the battery to see which side it needs to go on. When you figure it out tape the wire on the flat side of the battery down.
Step 6: Putting It Together
Put your battery and light in the case.
Step 7: Top
Pop the top back on.
Step 8:
Step 9: Done
And now you are done. I hope u like it. I don't really care if you don't because you'll get over it.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Get a drill!
    You won´t? I don´t care!
    Do you use this as a flashlight?
    kind of,its not as powerful as that but its a light...
    why did you put tape in the bottom? Plastic doesn't conduct electricity...
    It might have been as a non-slip layer to stop the contents shuffling around inside the box.
    The pictures are really helpful but perhaps mentioning how to determine which leg is the anode and which is the cathode would be helpful. The longer leg on the LED is the anode (+'ve) the shorter is the cathode (-'ve) this side of the LED usually has a flat edge as well. If you want your LED to last any length of time you really ought to consider a current limiting resistor. I guess in this case, the battery is of such low voltage and internal resistance is adequate. The title is a little misleading too, you haven't made an LED, you've used one. Sorry to nitpick
