Introduction: EASY AND EFFECTIVE DIY FIRE STARTERS!
Picture of EASY AND EFFECTIVE DIY FIRE STARTERS!
Here is a super easy way to make effective fire starters that will have your fire blazing in no time! With a burn time of 15-20 minutes these little bad boys will give you plenty of time to ignite your fire.
DON'T FORGET TO ASK ANY QUESTIONS AND MAKE SURE TO WATCH THE VIDEO!
Step 1: GATHERING THE MATERIALS
Picture of GATHERING THE MATERIALS
For this Inscrutable you will need:
- A roll of tinfoil or aluminium foil.
- A bottle of flammable liquid (I used Fuelite which is a petroleum spirit and this worked best for me).
- Several tealight candles.
- A lighter (or any other ignition tool).
- Cotton balls.
- Scissors.
- Sheet of plastic (I just used an ice cream container lid).
Step 2: CREATING a WAX BASE
Picture of CREATING a WAX BASE
Firstly what you will need to do is light around 5-10 tealight candles (you can do more depending on the size of the batch you want to make) and let them burn for a few minutes. Once the wax has heated up and melted you can go ahead and blow out the candles before dunking the bottom half of the cotton balls into the candle wax and placing them on a plastic sheet to dry/harden.
Step 3: ADDING TINFOIL TO THE BASE
Picture of ADDING TINFOIL TO THE BASE
While you wait for the wax to harden start cutting out a 2" by 2" square of tinfoil for each cotton ball. Once you have done this check that the wax has hardened then begin adding tinfoil over the wax at the bottom of the cotton ball. To do this pinch all 4 corners of the tinfoil so that they create little tabs (as shown in the pictures) then wrap the tabs around the rest of the cotton ball. This will serve as a dish to keep the wax from dripping away when the firelighter is ignited thus increasing its burn time.
Step 4: ADDING THE PETROLEUM
Picture of ADDING THE PETROLEUM
Now that you have created a wax base on the cotton balls and have wrapped them in tinfoil, it is now time to add the petroleum (other flammable liquids will also work). To do this there is two methods, you can carefully pour the petroleum onto the cotton ball or you can hold it firmly in place at the opening of the bottle and soak the cotton ball by briefly upturning the bottle. I would personally recommend the second method as it gave the cotton ball a more thorough and effective soaking than the first method but its really up to you.
Step 5: STORAGE
Picture of STORAGE
You have now completed making your firelighters but if you don't have any use for them immediately (which is mostly the case) then I would greatly recommend storing them in a zip-lock sealed bag out of direct sunlight or heat. This is because heat and sunlight can evaporate some of the petroleum in the firelighters reducing their burn time greatly (I left a batch of mine outdoors in the sun for 3 days as a test and they still had a burn time of around 5 minutes! This is still substantial but its a great decrease from the 15-20 minutes burn time they should have if kept properly).
CONGRATULATIONS! NOW LIGHT THEM UP AND ADMIRE YOUR WORK!
instructor12345 (author)2017-12-28
Great idea! Do you cut the plastic to stay on the bottom of the Cotten ball, or do you just pull the cotten ball off?
No, I actually sprayed a small amount of cooking spray on the plastic before setting the fire starters down to dry and harden. This made it much easier to remove them once they had cooled down without damaging the wax base.
gm280 (author)2017-12-18
Interesting. I may have to try this...
About This Instructable
779views
16favorites
More by DEEJAY246:AMAZING GRAVITY DEFYING COIN TRICK!EASY AND EFFECTIVE DIY FIRE STARTERS!HOW TO CRACK ANY COMBINATION LOCK IN SECONDS
Add instructable to:
