EASY Bike Seatpost Mount
6,522
96
9
Published
Introduction: EASY Bike Seatpost Mount
About: Italian maker, law student, DIY enthusiast. I make lots of projects, I fix lot of stuff and I like to save and reuse materials taken from broken stuff.
Hi everyone!
In this ible i'm going to show you how to make a Bike Seatpost Mount spending less than 5$.
Few months ago I made the Bike Handlebar/Fork Mount. It's a really good mount because it allows you to mount your action camera on the handlebar or on the bike's frame (both on rear and front fork).
But, since the seatpost it's inclined backwards (photo#4), you can't use that mount otherwise you will film just the sky.
So I made this mount, with the improvement of a tripod mount adapter, that allows you to incline the camera keeping it parallel to the floor (photo#4) and to film your rides from a different point of view.
Step 1: Materials & Tools
MATERIALS:
- bike bell (used or 1$)
- Tripod Mount Adapter (1,70$)
- Universal 1/4" Mini Tripod Mount Adapter (1,80$)
- 1/4'' Screw (1,20$)
- rubber gasket from beer bottle
TOOLS:
- dremel with cutting wheel
- caliber
- screwdriver
- marking pen
Step 2: Prepare the Bike Bell
All you need to do is to dismount your bike bell.
You have to keep just the lower part (photo#2) and you have to change the original screws with two other ones a little longer.
With a cutter or small pliers you have to brake all the plastic parts till the base will look almost flat like mine in the first photo.
Finally you have to mark a little "X" right in the center and drill a hole of the size of your 1/4'' screw.
Step 3: Cut the Squared Screw (optional)
I founded just a screw with a squared head (photo#2) so I had to cut it.
Of course you don't have to follow this step if you find a regular screw.
The space between the plastic support measures 0,8mm so I simply cut the screw to let it enter in that space.
As you can see in the last photo, after the cut it fits perfectly.
Step 4: Assemble Everything
Start to assemble it by inserting from the bottom the cut screw in the bike bell's base and tightening it by screwing on a flat nut.
Once it's very tight, you need to screw on another flat nut.
Now it's the time to screw on the tripod mount adapter, but since there is a small gap between it and the second flat screw, I decided to add a rubber gasket (taken from a beer) that will fill that space and it will help to keep all more tight.
Finally, keeping the tripod mount adapter screwed on, unscrew the second flat nut till everything will be tighter and sturdier as possible.
GoPro tip:If you have a GoPro don't worry! You just need to assemble it in the same way, mounting to the tripod mount adapter your GoPro case instead of the universal 1/4" screw.
Step 5: Enjoy Yourself and Film Your Bicycle Ride
The Bike Seatpost Mount it's finished!
In less than 10 minutes we have built an economic and adjustable seatpost mount for any type of camera.
All you need to do is to mount it on your seatpost tube by tightening the two screws, and to screw on your action or compact camera. (If you use a compact camera like my white one, remember to set the screen options so it will be off while recording to save battery)
NOTE: I suggest you to add a little piece of bike tyre (photo#4) to make it sturdier, steadier, and to avoid that the plastic (your handmade mount) will slip on the metal (seatpost tube).
Have fun and film your rides!
Thank you for reading my Instructable. ;)
Feel free to comment and ask if you need to know something!
manuelmasc
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    9 Comments
    What's the view like when you're sitting on the bike? Seems like it might be mostly legs :)
    You are both right and wrong!! ;)
    If you use a compact camera or a normal action camera, you will record exactly what you can see in photo#1 of this ible's intro! (maybe you could see a knee in the lower section of the screen if you did some heavy pedaling)
    But yes... If you use an action camera with a fisheye lens (photo#4 of the intro), or a GoPro, you will record a little also your knees at the sides like here for example
    i feel like this could also be placed on the front handle bars.
    of course! ;) since the bike bell it's made for the handlebar yes! it will works also as handlebar mount.
    A few months ago I made a mount for the forks and the handlebar ;) but the situation is this:
    this mount also works as handlebar mount,
    BUT the other mount doesn't works as seatpost mount. (because of the inclination of the seatpot tube)
    and, since (in my case) the seatpost tube's diameter it's bigger than the handlebar one, you have also to look the diameter of the inner hole of the bike bell ;) on the package of this one there was written "XL".
    thanks ;) please vote for me
    Anyway that's normal! also with original and professional mounts you will see your knees :)
    Using a bit of rubber the secure the mount is a great idea and I like the view you get from this mount. :D
    yeah jessy! ;) it's a very useful idea!! ahahah it fill the gap that you eventually could have, and it also helps to keep all steady.
    P.S. I'm glad that you like it! please vote for me :P I really want to win a robot t-shirt!! ahahha
