These fries are oh so EASY to make and tasty! I never liked the idea of deep frying and all the fat you intake when you eat it so I wanted to make something just as good but healthier for you. This recipe will have you eating delicious "fries" and feeling good about the way you made them.
Remove these ads by
Signing UpStep 1INGREDIENTS
Heat oven to 450 degrees
3 Russet Potatoes
Olive Oil or Sesame Oil or Vegetable Oil
Paprika
Garlic Powder
Salt
Lemon (juice)
The question you ask why the vinegar? Well here is the answer.
1) Water is used as a solvent to get the biopolymer (starch) into solution. When the solution is heated, the water helps the starch molecules to become disrupted and disordered (denatured). When dried, the disordered polymer chains become entangled and a neat film is formed. The process is called film-casting.
Vinegar: & Starch dissolves better if a small amount of ions (electrically charged particles) are present in the mixture; the polymer molecules become disordered more easily, and the resulting cast films are somewhat improved. These added ions interact with both the starch and the small amounts of other polymers (lipoproteins) that are present in starch. One way to add ions into the mixture is to use ammonium acetate. Ammonium acetate works very well in this respect because it forms ammonium ions and acetate ions in solution. However, ammonium acetate is not readily available. Vinegar is a practical alternative that you can use when making your own French Fries. Vinegar contains acetic acid which forms hydrogen ions and acetate ions, and (importantly) it is readily available. This is why adding a little bit of vinegar is recommended specifically when making home-made Fries.
So if you like crispy fries... denature the spuds... I always thought I would use potatoes to make VODKA not Denatured Fries. Bake then add the salt. or let the individual add salt to their taste. Amazingly this was discovered in 1880's in Paris, they became so popular " Chips" spread to England.. then to the good old USA.....
She actuelly cut them into Wedges (like some company we know)
we always fight over the ones that got glued to the tray (no teflon at the old days)
I did it once using Onion Soup Powder
- Cut potatoes (fries/wedges)
- poor some oil on the potatoes
- add 2 table spoon of Onion soup powder.
- mix
- cook for approx 30 minutes in pre heated oven
Eat...
I just put all the seasoning, oil and fries into a freezer zip lock bag and shook it around. :)
In my experience trying to mix something on it while on a tray is a bit of an annoying undertaking and there must be a better way you'd think.
Looks yummy though.
