3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
EASY PARTY BIKE
EASY PARTY BIKE
Ever want to listen to music while you bike, not using boring headphones? How about taking music to outdoor parties without having to lug a set of speakers around? This is a super-easy way to listen to music while you bike...
PLEASE: Post your ideas to add on to this in the comments section, for everybody else, and me, to do. There's never too much music or speakers to blast while biking!
Step 1THE INFAMOUS PARTS LIST
What You Need:
A cheap mp3 player, it will be alot easier if it takes a disposable battery...
A bike
A ton of duct tape
An old speaker... I used a speaker from a broken amp
Some batteries, the bigger (D) the better
A speaker cable
NOTE: You're mp3 player might break, thats why the cheaper the better...
30 comments
Apr 23, 2008. 7:07 PMDIY Dave says:
I would put some kind of cover over the cone of the speaker
Feb 24, 2011. 10:02 AMSky Woulf says:
i once mounted a set of 6x9 el cheapo's in the rear deck of a car, lots of sun, and trash flying around. so to protect them a little i glued some thin nylon i cut from a sleeping bag to the mounting gasket (the one that runs around the top of the cone next to the screw mounting holes). it vibrated nicly, and kept the sun/trash out of the cone.
Apr 29, 2008. 6:40 PMDIY Dave says:
I mean something like speakers come with when they are new. some kind of screen or something so your speaker won't get torn up
Sep 29, 2009. 7:48 AMbutterflycookies says:
if you touch the copper wire to one of the regular wires you will get a BIG boost in sound quality
Apr 23, 2008. 7:01 PMQuiksilver2693 says:
It would better to have power going straight to the speaker like some subwoofers.
Apr 24, 2008. 2:58 PMQuiksilver2693 says:
Like instead of having the speaker being powered by the mp3player have the speaker being powered from another source as well.
Jul 18, 2009. 7:01 PMDa_Fudge says:
That wouldn't work. You would damage your speaker very quickly. You have the battery across the speaker, that is going to be constantly pushing out the cone and will create a short.
Apr 27, 2008. 7:11 PMQuiksilver2693 says:
Possibly.
Jan 9, 2009. 2:24 AMzeroemission says:
every time you double the number of speakers, you get 3 extra decibels which is the same as doubling your amplifier power! just make sure you don't lower impedance too much as it will fry an amp. 4 ohm is the lowest you want to go with most amplifiers. car amps can handle 2 ohms.
2 X 8 ohm speakers that share the same + & - (parallel) on an amp = 4 ohm load. when you wire the same speakers with one's + to the amp +, and then it's - to the next speaker's + and THAT speaker's - to the amp - (series), you double impedance to 16 ohms. by combining BOTH techniques with 4 speakers, you can get 6 free dB with the same exact load on an amp. that's like doubling your power twice.
as mentioned too, putting speakers in a cabinet will help you get deeper bass by canceling the sound's out of phase back wave. it doesn't make as much difference at higher frequencies.
you don't really need to build a big heavy wood box either. sometimes car stereo installers test subwoofers in cardboard boxes which are much easier and lighter to work with. really, a little bit of box resonance might help "warm" the sound of your small speakers. it would sound cleaner with a solid box though.
if you can find them, some people have built really nice speaker cabinets using the heavy cardboard tubes used inside carpets shipped to carpet stores. that thick cardboard makes for a really good enclosure that isn't resonant.
more speakers = louder
a box = deeper bass
other than that, you need more power
Jan 9, 2009. 2:27 PMzeroemission says:
you could always get a sonic impact amplifier, but at $50+ (US), they cost a little bit of money. you can also get really cheap amplifier kits from 1 watt to 10 watts per channel if you can handle some wiring. the easiest thing might be to get a used pair of powered computer speakers and remove the power transformer, usually the plug (aka wall wart) and substitute battery power instead. these days people even throw working PC speakers out if they upgrade because they're so cheap. just make sure you match the power level. AA, AAA, C & D batteries are all 1.5 volt, so if you have a 6v transformer, you'd need 4 batteries. usually too, the power cable is color coded with the white striped wire being positive and the plain black negative.
Nov 1, 2008. 7:31 AMVasilcz says:
Please, how I heighten volume speakers? Play me ghastly quietly. Sorry for my English.... I'm 15 and I am form the Czech Republic
May 30, 2008. 5:42 PMcornboy3 says:
You could mount it in a cardboard box.
Oct 27, 2008. 2:17 PMravingking2008 says:
it will go soggy
Apr 24, 2008. 4:11 PMfatrickuk says:
I would suggest you to use an amp for the speaker though coz you might not get enough sound if you connect your mp3 directly to the speaker.
Apr 24, 2008. 3:37 AMrocknrollskwurl says:
id build a simpal speaker box (1/4 ply works best) and carpet the insaide and your bass will double
Apr 24, 2008. 12:46 PMrocknrollskwurl says:
just equal the treble and bass a little more
Apr 24, 2008. 2:54 AMRaisedByRobots says:
I always wanted to do something like this. Be riding my bike up to a stoplight with the music going 'FOOM FOOM bdup FOOM'. He he. Very cool. How long does the battery last when you're driving the speaker?
Apr 23, 2008. 4:46 PMtheRIAA says:
lol@ cheap cameras that take mirror images
Apr 23, 2008. 7:38 PMtheRIAA says:
well... if it's a webcam, it's understandable...
Apr 23, 2008. 5:40 PMLinuxH4x0r says:
I used to have a sanza e130. It's screen cracked. Twice. Nice job!
Apr 23, 2008. 7:22 PMLinuxH4x0r says:
too much pressure on it (probably keys next to it)
Apr 23, 2008. 5:28 PMVautikos says:
Great concept, but the execution is a little underpowered. I'd love to see a stepped-up version with a rechargeable amp and stereo speakers. Good work though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:heyzuphowsitgoin
