EASY RFID Add/Delete Tag Door Unlock
287
7
Posted
Introduction: EASY RFID Add/Delete Tag Door Unlock
Hello to all people like arduino and any other electronic section today i get
here a new and easy RFID Add/Delete Tag to Door Unlock.. why, because all tutorial its very cool in
"INSTRUCTABLE AWESOME" but it's for PRO programer hahaha so i try to make more easy for al people.
So.. in this tutorial you need :
-An Arduino board (UNO, Nano v3, Pro Mini, Leonardo, Mega 2560) in the sketch i add the connection mode for all boards.
-Protoboard or Breadboard (as you like to call this).
-Module RFID RC522.
-Relay module 5v.
-RGB (you can use 3 leds with 1Led / 1 resistence330 Ohms).
-Jumpers.
-And a simple Button module.
Step 1: First One RFID Module Connection to Arduino
So before I tell use any board of Arduino, I'm using an Arduino Nano v3 from RobotDyn (good quality)
The following table shows the typical pin layout used:
Arduino Nano v3:
MFRC522 Arduino Board
Pins Pins
RST ---> 9
SDA ---> 10
MOSI ---> 11
MISO ---> 12
SCK ---> 13
VCC ---> 3.3v (Important because this module only work with this voltage!!!)
GND ---> GND
i will add a photo later with all board connections... All Boards Connections Photo
Step 2: Pins Connections RGB, Relay & Wipe Button
I like to use the pins in order... i don't know why but like this...
---RGB------------------------------------------------------------------------------------------------:
*Pins Arduino Connectos, in the project i define the colors.
RED ----> PIN 2 ----> DENIED ACCESS
GREEN ----> PIN 3 ----> GRANTED ACCESS
BLUE ----> PIN 4 ----> STATUS ON or WORKING PROJECT
VCC ---> 5v
GND ----> GND
---Relay 5v---------------------------------------------------------------------------------------------:
Relay pin signal ---> PIN 5
Relay + ----> 5v
Relay - ----> GND
---BUTTON MODULE-------------------------------------------------------------------------------:
Button + ----> 5v
Button - ----> GND
Button Signal ----> PIN 6
Step 3: Start Resource... You Need
In this next step you need a MFRC522 Library of Miguel Balboa "ALL CREDITS!"
Library Miguel Balboa RFID <---- Download here and put in the folder of the arduino..
If you are new (me too) and don't know "where i put the library?"
In the folder of Arduino IDE you can see a folder called "libraries" open and put inside this
exist another folder called "lib" don't touch this :)
I add here the sketch to download and do all you want with this AND SORRY FOR MY BAD ENGLISH
HAVE A GOOD DAY TO ALL. Sketch Download
if you don't trust download use the website Virustotal.com to scan virus ;)
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    Thanks for sharing :)
