Introduction: EASY Radio Receiver Arduino
Picture of EASY Radio Receiver Arduino
Hi,
this is my first instructable, but isn't the first Arduino project...
Let's Go...
Step 1: Get All Needed Parts (Parts List)
Picture of Get All Needed Parts (Parts List)
1 - Arduino Uno/Nano
1 - 10k Potenciometer
1 - Radio Receiver TEA5767
Some Wires
Step 2: Connect Wires
Picture of Connect Wires
Connect all wires as shown in the picture...
Step 3: Build Code
This is the code that you will use.
You will need TEA5767Radio.h library for arduino
So, the includes will be:
#include <Wire.h>
#include <TEA5767Radio.h>
#include <math.h> //this is to round readed values
then we will declare variables:
TEA5767Radio radio = TEA5767Radio(); //declare radio as TEA5767Radio type
float freq, lastfreq; //freq and lastfreq should be float because we will use decimal values in MHz
int sensorValue; // this is to read potenciometer value
Now let's setting up arduino:
void setup(){
Wire.begin();
Serial.begin(9600);
Then let's create our loop:
void loop() {
sensorValue = analogRead(A0);
freq = (sensorValue * (20.5 / 1023.0))+87.5;
freq = freq*10.0f;
freq = (freq > (floor(freq)+0.5f)) ? ceil(freq) : floor(freq);
freq = freq/10.0f; //round the freq value to a 1 decimal place
if(lastfreq!=freq){
lastfreq=freq; //save frequency to check if frequency was changed
radio.setFrequency(freq); //sett choosen frequency
Serial.print("Frequency: ");
Serial.print(freq);
Serial.println("MHz");
Step 4: Finally
Picture of Finally
Finally connect your headphones, start your Arduino, and start to listen your favourite radio...
varung42 (author)2017-03-07
What is the range of frequencies that we can hear?
magnocampos (author)varung422017-06-28
I'm sorry for later answer...
you want to know the range that we can hear ou we can set on this?
we can hear 20hz to 20000hz +/-
In the project we can set between 76Mhz and 108MHz
cubetron (author)2017-01-08
Very good project, simple and effective to start using the radio module. I suggest that you add a couple of lines to the wiring description to state that each Arduino board has different SDA and SCL pins, so if you do not use UNO (or Nano) you have to change wiring accordingly. For example MEGA has:
SDA pin 20
SCL pin 21
magnocampos (author)cubetron2017-01-11
Thanks for your tip...
I'll update the post... But I need to test it first.. :P
Nematic! (author)2016-11-16
Nice project :)
magnocampos (author)Nematic!2016-11-16
Thanks... :D
DIY Hacks and How Tos (author)2016-11-16
Cool Arduino project. Where can you buy the reciever module?
Hi, Thanks,
I bought on ebay for $US 4...
http://www.ebay.com/itm/TEA5767-FM-Stereo-Radio-Module-for-Arduino-76-108MHZ-With-Free-Cable-Antenna-/221944971609?hash=item33acf38159:g:c1MAAOSwZVhWTXJZ
About This Instructable
3,955views
53favorites
License:
More by magnocampos:EASY Radio Receiver Arduino
Add instructable to:
