3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
EL Driver Board
EL Driver Board
Previously, I made a homebrew EL wire driver to be used with a LilyPad Arduino  (http://www.instructables.com/id/Programmable-LilyPad-EL-Wire-Dress/).  We at Electric Stitches (and with the help of iNMOJO) designed and made a pretty snappy looking sewable EL Driver available here: http://bit.ly/q4DnXP.  The board, used in tandem with the LilyPad, will give you control of the EL wire and allow you to flash and fade the strands of light in response to any input to the LilyPad.  And, with a bit of code, you can create beautiful patterns and illuminated lines as you strut your wearable down the street!
As this is an OSHW board please feel free to download the designs from: http://electricstitches.com/
EL Wire can be dangerous and can give you a mild shock. We have taken an extra step and added conformal epoxy coating to help prevent unintended shocks
Step 1Materials
Materials
For this project you will need:
Total Cost: $40
5 comments
Aug 25, 2011. 5:48 PMstagr.lee says:
I have this experiment repeated. Biggest debug I had to do was unplug the EL Wire power inverter while the USB is hooked up to get the program uploaded. With the inverter hooked up to the circuit and the USB computer link hooked up, the computer and the Arduino wouldn't talk.
THANKS! Looks great.
Reading your code, I've noticed a few things. First, there is never a state where all the EL Wires are off (except between the square wave flashes) . 2nd, there is never a state where there are more than one EL Wire on. Was this done for electronic reasons or artistic reasons? I'm wondering if there is a limitation of the EL Wire power inverter or the Triac driver board. The design I'm at will have a lot of all on states and all off states.
Look forward to your thoughts Quasiben.
Aug 25, 2011. 7:23 PMstagr.lee says:
Clever! Should I worry about all off? I'm running the same 3V 5-15' inverter you have linked to Coolight.com and my sequence will have 5 seconds of all off. Making essentially a Smiley Cheshire Spider that disappears.
Using 3 AAA batteries at 4.5V. Looks good...
Aug 5, 2011. 3:13 PMEddy Dean says:
Great, but, can this be washed?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:quasiben(Electric Stitches)
